Power steering problem @ auto-x--looses assist... - Page 4 - Subaru Impreza WRX STI Forums: IWSTI.com
STI Products
Go Back   STI Forums > > > Power steering problem @ auto-x--looses assist...
Old 03-11-09, 02:50 AM   #31
Lutfy
Advanced Contributor Level 1
Car: Silver 04 WRX STi
Fav Mod: Stage 2
Lutfy is on a distinguished road
Default Re: Power steering problem @ auto-x--looses assist...
Originally Posted by STEye View Post
No need to overfill, just fill to the max for the appropriate temperature. Most likely caused by low level of fluid. All it takes is a little bit of weight shifting, which in turn sloshes the PS fluid around. Then in goes the air bubbles, then you loose PS!
Well bringing it up from the dead. The fluid lasts me 2-3 months at best (I believe ATF is hydroscopic as well?). Anyways, I am burning the crap out of my oil (partially because of the freaking Dubai heat). That said, I did do a search for oil coolers. Anyone has a kit tested out? If so, care to share the part/source?
Thanks in advance.
Lutfy
Lutfy is offline
Old 05-19-17, 06:17 AM   #32
Scargo
Fav Mod: Driver lobotomy
Scargo is on a distinguished road
I am having a loss of power steering when the fluid gets hot (I am assuming fluid heating is the trigger).
This is a track car and it has a PS cooler exposed to the air. After a few laps the PS goes away. Happened in three successive sessions. Once cool it works again for a while.
I am using new Redline PS fluid. AN lines and fittings are new for this season. Car did not have a problem last season. The reservoir is an aluminum aftermarket version. No visible signs of bubbles or foaming and car is fine during normal street driving. No visible leaks. Fluid is not overfilled/it is at normal height. Thompson course is fairly tight. Could air be getting in? Pump shot or rack shot but work when cool?
Trying to be as good as my car... Try this jalapeno son. It ain't hot! Pictures
Scargo is offline
Old 05-19-17, 06:49 AM   #33
SubySal
Advanced Mastery Level I
Feedback Score: 1 reviews
Fav Mod: everything done so far
SubySal will become famous soon enoughSubySal will become famous soon enough
I would lose p/s in my 2004 2.5RS when going through a slalom. It was annoying. I believe the cause is the Redline ATF I was using. Get rid of it. Flush the system with Subaru synthetic. I know that seems odd, but if I were you that's what I would do. I have no issues with the power steering in my STI using Subaru synthetic. It's a stock system. Last year I did a Time Attack event where ambient temp was 113F. The car would not launch because it kept pulling timing, but the p/s worked fine. I also did a track day that toasted my brake pads, but again p/s was flawless. I'm in my fourth season of racing on that fluid and still it works just fine. I would also make sure the p/s belt in in good condition and tensioned properly.
Additionally a friend of mine was having this issue last year in his 2005 STI. I said you're using Redline ATF. He said yes. I told him the same thing. I haven't asked since, but he hasn't complained about it anymore so I figure he changed it out. I will swear by Redline motor oil all day long, but aside from brakes I stick to OE fluids in all my vehicles.
SubySal is online now
Old 05-19-17, 08:03 AM   #34
Scargo
I am glad that worked for you but I am skeptical. Here's the thing: I lied. It's a good friend that is having the issue. Similar car/setup. My track car with a cooler and Red Line D4 ATF has not had an issue. Same day, on the same track. While I see that Red Line does make a power steering fluid, it's not what I used. I think my buddy used the same as me but I cannot verify that at this moment. I think I saw a D4 bottle in his shop...
I am however, now suspicious about the level of fluid in his reservoir. I mean, this is an experienced track guy and instructor. However, I did see the level was 1/2" below the baffle plate in the reservoir and under hard cornering it might have sucked air. He said the level was OK.
Update: Spoke to Red Line. Neither D4, D6 or their "Power Steering fluid" (in the white bottle) are hygroscopic so they cannot create gas when hot (like in brake fade). He recommended the D4.
Scargo is offline
Privacy Policy
