Old 12-26-2006, 02:54 PM   #1
Car: 06 Subaru WRX STi
Fav Mod: The Hooptie
IWSTI Addict since: Jun 2006
Send a message via MSN to jungo75 Send a message via Yahoo to jungo75
Default DCCD Doubts
Is it the DCCD that makes the car pull on uneven terrain, like a messed up street or something like that or is it a problem with the car? I was reading that the car puts the power where it needs it, so I was thinking its the car and not a problem. Does anybody have a different take on this one?
jungo75 is offline   Reply With Quote
Old 12-26-2006, 03:08 PM   #2
Car: 04 WRB STi
Fav Mod: Trailer Hitch
IWSTI Addict since: Feb 2004
If you are refering to the car pulling left to right when on surfaces with uneven traction, i.e. left side on pavement, right side on dirt and it pulls to the right when you step on it,
Then it is actually the limited slip diffs in the front and rear that cause that, not the center diff (dccd)
don
donmei is offline   Reply With Quote
Old 12-26-2006, 07:43 PM   #3
Thanks again don.
Old 12-26-2006, 07:52 PM   #4
IWSTI Addict since: Sep 2006
If the street is messed up, with big grooves from the big trucks, thats called tram lining, its where your tires run in the grooves and it basically follows them. Nothing wrong with the car, you will get used to it.
rjacobs is offline   Reply With Quote
