| STI Master Car: 04 JVP STi Fav Mod: Blitz NUR Spec R Location: B.F.E, Texas Posts: 7,985
IWSTI Addict since: Apr 2004 Trader Rating: (3) | So that was my big gift from *cough* the best girlfriend ever . To start off, the COBB piece is nice looking. (Not that it matters because you can't see it but its nice) The instructions are straight forward and really just a formality. By that I mean if you can't figure out how to put this thing in without the instructions then you have no business owning any tools. ![]() My one gripe is that I hade to modify the shifter to make it fit. The problem was that the shaft on the shifter was too small for the reverse lockout cable to seat properly. I don't know if mine was a bad one or what, but I have never read of this problem before. Basically I had to bore out the shaft so that the cable would seat properly. (yes I'm sure I could have sent it back to COBB and got another one but I didn't feal like waiting two weeks to get it) So I drilled out part of the shaft on the handle making this everything BUT a bolt on instalation. Everything else I love. The shifts are rediculosly short, the handle sits just where I want it, and the shifter's position is changed sligthly (for the better IMO) This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Silver Member Car: 04 JBP WRX STi Fav Mod: ProTune by Hill at Agile Location: Greensboro, NC Posts: 324
IWSTI Addict since: Mar 2004 Trader Rating: (0) | Hhmmm, I did not have that problem. Good for you fabbing a fix! Mine loosened up once, other than that it's been great. I've got the Cobb installed on top of an STi short shifter that has Kartboy bushings. I couldn't be much happier with this set up... not quite the S2000 "snick-snick" I was targeting, but close enough! |
| | #4 |
| Indiatr0n in yo IWDPL
Car: 05FTW OBP STi Fav Mod: Brum Brum Location: downtown Chicago Posts: 48,821
IWSTI Addict since: Jun 2004 Trader Rating: (11) | Mine installed with no issues... ...and I haven't had the shaft slippage problem others have either. |
| | #5 | |
| Subaru Addict Since 2003
Car: 04 WRB STi - 07 Blue Fav Mod: TIC Click Kit & Cobb SS, RCE Springs and Plates w/Cobb Stg2 Protuned Location: MI Posts: 1,303
IWSTI Addict since: May 2003 Trader Rating: (5) | Quote:
| | #6 |
| Spec C Club Car: 06 STi WRB Fav Mod: Spec C Roof Vent:Cobra Seats:Custom Cage Location: MASS-HOLE Posts: 2,216
IWSTI Addict since: Aug 2006 Trader Rating: (1) | no issues here and love the shifts. Sooo much shorter than stock and would highly recommend this. One of the biggest pluses to me is the fact that you can adjust the hieght of the shifter. I love mine tall cause it's less of a reach from the steering wheel to shift . . you know when you in the middle of that nice hard turn and you heel toe from fourth the third I don't like to keep my hand off the wheel for too long !!!!!! |
| | #7 |
| The Hoff Fan Club, member #001 Car: 05 WRB/Gold Fav Mod: Hood Scoop Homer Location: Where ever The Hoff is! Posts: 10,394
IWSTI Addict since: Jul 2004 Trader Rating: (4) | glad you like it! I'm thinking of picking one up for myself, but how is the shift effort? Has it increased alot? |
| | #8 |
| Senior STI Driver Car: 05 Subaru WRX STi Fav Mod: ECUtek Location: Long Island, NY Posts: 316
IWSTI Addict since: Oct 2005 Trader Rating: (0) | The shift effort changes as you increase or decrease the height so its hard to say, but overall yes. I think it gives it a more positive feeling though, its near impossible to miss a gear. Ive had mine for a while and love it. I just added tic pivot bushings and it made it even more solid, theres absolutely no movement or play in the shifter when the car is in gear, which makes it feel awesome. |
| | #9 |
| dances with roads | I had a hard time lining up the cable housing to get the pin in the reverse lockout cable, but there was no need to bore anything out. Yours is the first I have heard of that issue. |
| | #10 |
| Junior STI Driver | I had to tap the reverse lock-out cable end to get it to seat in the Cobb shift lever. It just felt like the production tolerances from the cable maker and Cobb were at their max/min to make the fit an light interference fit instead of a slip fit. |
| | #11 | |
IWSTI Addict since: Apr 2004 Trader Rating: (3) | Quote:
| | #12 |
| Spec C Club
Car: 05 WRX STI - Spec A Fav Mod: Starving my STI Location: Lightweightville, Canada Posts: 1,734
IWSTI Addict since: Sep 2006 Trader Rating: (15) | I've heard mixed reviews on Short Shifters... I'm fairly happy with the stock one, but the throws could be a BIT shorter... anybody compare the Kartboy SS to the COBB one? |
| | #13 |
IWSTI Addict since: Aug 2006 Trader Rating: (1) | ^a friend on here has a kartboy and another driver compared his to my Cobb and said that the kartboy was shorter. This was when i installed mine and didn't adjust the left side of the shifter, the one that adjusts the throw. Since I've adjusted mine to all the way up, the shortest throw you can have, the Cobb is def. shorter. My shifter in 2nd 4th or 6th looks like it's in neutral and you actually have to grind down the metal plate that surrounds the shifter assembley in the top left corner. If you do not do this you won't be able to put the car in 1st or 3rd, thats how short/different the throws are. Definetly much more "effort" in shifting but I also installed the bushings the same time and they're great. No shift play at all and very solid feel. You get use to it. ! |
| | #14 |
| Grassroots STI Racer | same problem here,had to drill out the seat inside the shifter so the reverse lockout cable would seat properly,and that was after Cobb sent me a new one thinking the first one was defective,shifter worked great for a month untill it loosened up and started vibrating,now the lower set screw wont tighten enough to lock the blue assemble onto the lower shift rod,Cobb is again sending me a new shifter with what they say are the correct tolerances,so far customer service has been great,the problem is the product was unfortunatelly designed poorly now my car is down till it arrives |
| | #15 |
| Iron Fisted | Yea, I've only heard of a few problems with this issue. Otherwise, only good things. This ad is not endorsed by this member. Please register or login to hide this ad. |
