Old 12-10-2006, 06:43 PM   #1
Car: 05 STI
IWSTI Addict since: May 2006
Send a message via AIM to wonton2049
Default car jerks at downshift
delete me
wonton2049 is offline   Reply With Quote
Old 12-10-2006, 06:46 PM   #2
Car: 05 STI
Old 12-10-2006, 06:58 PM   #3
Car: '05
Fav Mod: AP
IWSTI Addict since: Apr 2006
why would you down shift to 3rd gear if you're at 5k rpms in 4th?
dannyblaze_07 is offline   Reply With Quote
Old 12-10-2006, 07:01 PM   #4
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
IWSTI Addict since: Aug 2005
Trader Rating: (78)
Could it be your heel-toe needs practice?
Old 12-10-2006, 07:18 PM   #5
Car: 07 STI OBP
Fav Mod: flat black rims
IWSTI Addict since: Jul 2006
Send a message via AIM to JustinH
^ +1
JustinH is offline   Reply With Quote
Old 12-10-2006, 07:52 PM   #6
Fav Mod: Driving School / Trunk swap (no attention ftw)
IWSTI Addict since: Sep 2006
^^ agreed...sounds like when you heel toe, your slipping the clutch, but not fully engaging it (maybe resting your foot on the clutch a little too hard), then around 3k it catches, thus the jerking.
Next time you heel toe downshift, MOVE YOUR FOOT...report back as to whether or not this still happens.
~Jesse
mgsm666 is offline   Reply With Quote
Old 12-10-2006, 08:00 PM   #7
Car: 2005 CGM/Gold STi
Fav Mod: Rocken the 08 nissan sentra!
IWSTI Addict since: Dec 2005
Trader Rating: (12)
purreplayya69 is offline   Reply With Quote
Old 12-10-2006, 08:04 PM   #8
Car: RIP 02 WRX
Definitely the car.
But seriously, just work on your technique, it'll smooth out eventually.
Old 12-11-2006, 04:23 AM   #9
Car: 06 STI WHITE
Fav Mod: Driver improvement.
IWSTI Addict since: Aug 2006
Replace your fluids and report back.
SPOOLN STI is offline   Reply With Quote
Old 12-11-2006, 09:02 PM   #10
Car: 05 STI
as for the heel toe issue, it shouldnt be the issue. been doing it for a while. the brake and gas modulation may not always in perfect sync but its good imo.
lemme try again
scenario.... drving down the road in fourth at about 5.5rpms, hit the brakes, heel toe to third and go through the turn. now as the rpms are dropping mid turn at about 4.5k rpms to 3.5k rpms?, the car does a jerk similar to fuel cutoff or somthing (could it be fuel cut off?). lemme say again, the transition from 4th to third is smooth. after about dropping to about 3k rpms, the car just jerks.
this has happened through similar turns even when im already driving through in third gear (did not downshift or anything.... was already crusing in third). its a bit of a sharp turn and it always happens when the rpms start to drop and get around the 3k range (guesstimate).
Old 12-11-2006, 09:05 PM   #11
Car: 05 STI
as for jesse... that cant be my foot resting. as soon as i heel toe, i dont ride the clutch or even cover the clutch after.
any other ideas? you all know how it is!! i cant take this not knowing whats wrong with my car!!!!
Old 12-11-2006, 09:11 PM   #12
Car: 05 STI
