| | #46 | ||
| Junior STI Driver | Quote:
WI is basically an octane booster to fuel, like racegas. While I say that 5-6psi is not a harset number yes you cant run more boost with WI (maybe more maybe less) The fact is that if tuned for it, it can help keep your engine together better than without it... like racegas Also by "tuned for it" can mean your basic setup, you just adjust the WI to spray the right amount w/o interfearing with anything else. If your engine runs fine now, you adjust water to spray w/o adjusting yoru basic setup then you can lower intake temps... if your run out your still at your basic tune, like your engine runs today (although why would you run out of water??) Like someone else said, they know about WI they just choose not to run it, fine, that is an informed decision but when someone asks, and another person brings up WI people shouldnt knock it if they dont understand it. This ad is not endorsed by this member. Please register or login to hide this ad. | ||
| | #47 | |
| Spec C Club Fav Mod: stockboy Location: massachusetts Posts: 1,629
IWSTI Addict since: Sep 2003 Trader Rating: (0) | Quote:
| | #48 |
IWSTI Addict since: Sep 2003 Trader Rating: (0) | a good indicator of how well a particular product works is how popular it is. there was a time when nitrous was thought of as nothing more than a way to blow up you engine. now its considered the easiest and cheapest way to make huge power. its widely used on daily driven street vehicles. turbos were also difficult to tune until fuel injection came about and changed all of that as well. now as for WI, how popular is it really? its not something that i have ever seen used, at least not in the world of V8's and i have never even seen it on any of the import build ups that i have read about. i have only heard from one man who uses WI and he uses it on a carburated, twin turbo, small block V8, that is in a BOAT. yes, it was mentioned that cars in WRC competition use it but that really does'nt mean its good for any street car. top fuel dragsters use Nitromethane to make huge power, but that does'nt mean its something i need. |
| | #49 |
IWSTI Addict since: Sep 2003 Trader Rating: (0) | here is an interesting technical overview of water injection. i think it sums it up pretty well. http://www.rallycars.com/Cars/waterinjection.html |
| | #50 | ||
| Spec C Club Car: Motorcycles Fav Mod: Student Location: Western Washington Posts: 1,929
IWSTI Addict since: Oct 2003 Trader Rating: (0) | Quote:
I suppose if the system was only designed to run in fresh water, maybe. But I think you'd be a lot dumber to run on the water you're running in than to have a pure water reservoir. As for popularity reflecting how well something works, that's hardly the case. Popularity reflects how easy something is to use..... Also, your link doesn't work... | ||
| | #51 |
| Junior STI Driver Car: Math, Physics, Engineering Fav Mod: Manager...... Location: Wayne,NJ Posts: 53
IWSTI Addict since: Jan 2004 Trader Rating: (0) | Well let us dispell this notion of using dirty water right now... No way in hell.... An yes Crash it is true that the egine is ont the one that suffers, but you have o understand that WI systems use very fine misters and regulators that cannot ahndle dirt. All my water is filtered and in truth i normally use bottled water if i can, just for that extra purity. ... DO NOT USE LAKE WATER..ect. Now as for furhter application, WI is also used in aircraft, for takeoffs. That sudden burst of power from "exploding" water molocules is an unbelievabel power source. and yes i know it does not truly explode but when water turns to steam at an insanly rapid rate it creates power. The 40 hp gain is not unrealistic at all... again i go back to sating if you really haven't done the research, keep an open mind. One of the main reason you don't see WI on standard auto's to day is 2 fold.... ONE= oil profits but 2 is that they are expensive to make, operate, maintain and control. I adjust mine all the time depending on what i am doing and what the weather is. On a foggy morning when i am going fishing i dont' neet more water, the air has enough moisture to control the burn.... And crash, you are right you put dirty gas in your car every day, but i dont' know about you but every race car, hotrod, musclecar, Import and daily driver i have ever owned,or built has two things.. a fuel fitler and an air cleaner............ sorry about the typing guys... it has been a long day....... If you have other questions... keep em comin |
| | #52 |
IWSTI Addict since: Jan 2004 Trader Rating: (0) | Another thing i think is important to understand is that when using WI you can run leaner and leaner is faster... as long as you are not burning cylinders... hee hee beeen there. Running lean is the key to power and perfromance, and of course MPG. Take into consideration water expansion VS Fuel.....something to think about |
| | #53 | |
This is one of the parts of WI i think people are missing - when the cylinder fires the water is vaporizing. The volume of a gas proportional to the volume of a liquid is 1000 times expansion, creating a lot of extra pressure (read: power) and also making use of the thermal energy that is normally dissipated as heat. | |
| | #54 | |
| | #56 |
IWSTI Addict since: Oct 2003 Trader Rating: (0) | Same - I still think you just don't understand how versatile the stuff really is. It's not that hard to set up, and you can add a WI system without tuning at all - in the case of the STi, or any car with variable valve timing, the stock ECU just advance timing and make a little more power automatically. |
| | #57 |
| Junior STI Driver | I have to agree with crashsti here. From a thermo view of engine combustion, water will take energy out of the system to make steam. And this energy is what expands the gases that moves the piston. Sure you'll make some stream, but I don't see a net gain here. More like a net loss if you compare water to the fuel/air mixture that you just displaced. Also I think you guys under estimate the amount of energy needed to vaporize water at +14 bar. |
| | #58 |
IWSTI Addict since: Oct 2003 Trader Rating: (0) | lol..... considering 14 bar is over 200 psi, i'm quite sure it takes a lot of energy. The thermal energy in the engine only increases expansion a small ammount - the combustion of the gasses is where most of this energy comes from. The steam expansion will make up for, if not surpass, the extra energy provided by the expanding gasses from thermal energy. At the same time you'll run a more sustained temp, and aviod detonation. |
| | #59 |
IWSTI Addict since: Sep 2003 Trader Rating: (0) | my point is that on a street/strip/auto-cross destined vehicle, water injection may pose more of a tuning headache than a benefit. so, for the majority of people who own an STi, WI may not be the best option and the money spent on WI could be better spent elsewhere. there are many companies offering what are essentially guaranteed performance packages. all the R&D has been done for you. if the package claims 350 horses at the rear wheels you ar emore than likely going to see just that, maybe more because most companies purposely underestimate the numbers. there is no such thing as a free lunch. This ad is not endorsed by this member. Please register or login to hide this ad. |
