Old 07-14-2007, 02:23 PM   #16
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
IWSTI Addict since: Jun 2004
2007 Postwhore King
Default Re: So I installed my COBB Shifter yesterday..
Pictures from my install for reference:
More pictures here: http://www.iwsti.com/forums/showthre...208#post960208
And it's definitely shorter than before. I feel spoiled when I get in any other stick-shift, my shifts are so short and crisp that cars that used to feel super short to me before (S2000) don't seem that short anymore!
Old 07-14-2007, 02:23 PM   #17
Car: 06STi K7GSX-R 600
Fav Mod: Stage 2 Catless!!!!!
IWSTI Addict since: Jul 2007
UPS FTW!!! here COBBY COBBY COBBY. i am ordering GFB SS in a couple days. you should check out this link, expensive but sweet! look at the "SHIFT BOOTS AND RING SET" http://japanparts.com/db/partslist.p...dle=2&small=12
WRC~06~STi is offline   Reply With Quote
Old 07-14-2007, 08:06 PM   #18
Fav Mod: One that doesn't cause problems.
IWSTI Addict since: Jul 2004
Trader Rating: (-1)
Cobb is a pain in the but to install. I had tho have them send me new shifter twice but finally it is working great. You do have to cut that upper left corner Or you will bang up in first gear with the throws shorter. Also be careful to long on the bottom and you will wear out the front part of the rubber shift boot. I glued some special teflon material to the shifter rod and the rubber boot so that wear is not an issue.
maximus is offline   Reply With Quote
Old 07-14-2007, 08:27 PM   #19
Car: 06 STi
IWSTI Addict since: Oct 2006
I just noticed this thread is alive again. FWIW I ended up ditching the COBB shifter and putting in a Kartboy due to the COBB bolts breaking again and again.
j87w is offline   Reply With Quote
