Old 11-22-2006, 04:14 PM   #1
Car: 05 Subaru WRX STi
IWSTI Addict since: Sep 2005
Default hi guy need help with oil
guy im thinking of moving back to canada and i need to change my tranmission oil an rear differential any recommendation, and no arguement lol
thanx guys
shad2312 is offline   Reply With Quote
Old 11-22-2006, 05:10 PM   #2
Car: 05 WRX STi CGM/Slver
IWSTI Addict since: Mar 2004
I've been using Valvoline 75w90 for the transmission and the Subaru STi specific LSD gear oil for the rear diff. No problems with either for 15k+ miles.
Pyrex is offline   Reply With Quote
Old 11-22-2006, 05:12 PM   #3
IWSTI Addict since: Jul 2004
Same here.
Valvoline 75w-90 in the tranny and Subaru LSD oil in the diff.
klaymon is offline   Reply With Quote
Old 11-22-2006, 06:11 PM   #4
thanx guys ive been looking online where to buy Valvoline 75w-90 , and cant find anything
Old 11-26-2006, 11:17 PM   #5
Car: '05 CGM/Silver
IWSTI Addict since: Apr 2004
Something interesting maybe (no personal exp.):
http://www.performancemotoroil.com/a...Valvoline.html
Spuncorpceo is offline   Reply With Quote
Old 11-27-2006, 07:48 PM   #6
I get mine at NAPA
Old 11-27-2006, 09:19 PM   #7
Advance Auto has it.
Old 11-27-2006, 09:49 PM   #8
Car: 06 STI
IWSTI Addict since: Mar 2006
Is it ok to top off the tranny with Valvoline? My tranny has always been just a little low, a tiny bit below the low line. I wasnt sure about mixing Valvoline with factory Subaru oil.
k4rma is offline   Reply With Quote
Old 11-28-2006, 05:20 AM   #9
Car: 06 obp/g sti
Fav Mod: Whiteline sways
IWSTI Addict since: Feb 2006
Send a message via AIM to bickford
i toped mine off with the 75-w90 valvoline about 2k ago and it has been fine. Im going to switch to all valvoline this weekend.
bickford is offline   Reply With Quote
Old 11-28-2006, 05:38 AM   #10
Car: 05 Black on Black
IWSTI Addict since: Oct 2004
Although good find, I get the impression that web site is slightly biased towards amsoil. I put the Amsoil synthetic gear lube that they used in that test, and it was smooth as hell when I first put it in. 20K later, its real notchy, and I want it out of my tranny. I'm going with Valvoline next time around.
Standard Subaru LSD oil in the rear diff for me.
DoubleURX is offline   Reply With Quote
Old 12-03-2006, 05:20 AM   #11
Car: 04 JBP WRX STi
Fav Mod: ProTune by Hill at Agile
I looked all over my home town for Valvoline... NG. Advance and Autozone had "Coastal" brand.... which I never heard of. O'Reilys had "Lubrimatic" which I used to use in my 150 hp Merc outboard gearbox for many years without problem. Pep boys, you name it only had synthetic 75/90 GL5, not Dino. Non synthetic 75/90 just doesn't seem too popular(?) in stores.
I went with the Lubrimatic 75/90 GL5 NS. All is good. I was changing out 80/90 GL5 that the Jag/Subaru dealer put in because I couldn't shift it into 2nd when cold.... and cold wasn't very cold like 38 degrees!
Shifts great now. From all I have read 75/90 GL5 NS and Subaru spec LSD oil for dis the way to go.... be carefull not to overfill. Let it drain from both plugs for a while. I put in about 3.7 quarts. Let it sit overnight and then topped off... only 4 quarts to the full line... so some of the old oil must of been left in there, capacity is a little over 4 quarts.
Sti491 is offline   Reply With Quote
Old 12-04-2006, 05:09 PM   #12
I'm using Valvoline dino 80w90 (bought at local shop, couldn't find 75w90 locally). It worked fine all summer, but at -25C (-13F) it makes for a pretty stiff shifter and there is a lot of drag in tight corners until it gets a bit of heat in it. At -10C and above it was great.
corey_dyck is offline   Reply With Quote
Old 12-04-2006, 05:15 PM   #13
Car: 2005 OBP STi
Fav Mod: CBE
IWSTI Addict since: Aug 2006
from having experience with stuff like this from different manufacturers, id use what subaru uses. this is just my opinion.
johnlude85 is offline   Reply With Quote
