| | #16 | ||
| Junior STI Driver Car: 05 WRX STi CGM/Slver Location: Flagstaff, AZ Posts: 159
IWSTI Addict since: Mar 2004 Trader Rating: (1) | Quote:
Yes, it is fine to drive on pavement with the diff open. Auto opens the diff when making tight turns anyway. Quote:
This ad is not endorsed by this member. Please register or login to hide this ad. | ||
| | #17 | |
| | #18 |
| Spec C Club Car: 2005 OBP STi Fav Mod: CBE Location: Milford, NJ/Allentown, PA Posts: 1,103
IWSTI Addict since: Aug 2006 Trader Rating: (0) | [quote=Pyrex]Yes, it is fine to drive on pavement with the diff open. Auto opens the diff when making tight turns anyway.[quote] so is there an advantage to using open on the street, or is it mostly used for the track? how is the power distributed to the wheels in open, 45 front and 65% rear? its noticed and heard that its best to leave it in auto, but if leaving it in open on the street (every once in a while i like to hear a little rubber burn, so sometimes i launch at a stop light from 1st to 2nd) will that be better for the car then leaving it in auto allowing the rears to break loose a bit easier then trying to store all the energy in the axles? sorry for all the questions, ive just always meant to ask and never have. |
| | #19 | |
<o></o> The torque split is always the same no matter how you have the diff set, the amount of slip that is allowed between the front and rear is what changes. The 04-05s are 35f/65r, the 06-07s are 41f/59r iirc. <o></o> <o></o> If you are launching hard enough to break loose you will probably break something sooner or later, but my guess would be if you allow the power to exit through the rears breaking loose instead of letting the transmission, differentials, and axels take it all, is probably better.<o></o> | |
| | #20 |
IWSTI Addict since: Aug 2006 Trader Rating: (0) | subaru should have made another notch below open diff that would disable the front axles leaving it completely rwd. that would make an awesome consumer car, the ULTIMATE consumer car imo. the skylines have that option, i wish the STi,s did too. |
| | #22 | |
| S204 Racer Car: RIP 02 WRX Fav Mod: 2004 Aspen White WRX STi Location: Cincinnati Posts: 3,614
IWSTI Addict since: Dec 2005 Trader Rating: (1) | Quote:
Open means that the center differential is not applying any clamping force. On 04/05 STis 65 percent of the torque is routed throught the rear wheels. However, the DCCD setting is more of a suggestion than an abolute. | |
| | #23 |
| The Next Petter Solberg Car: 200? WRX STI Fav Mod: Super EX/RM-01A Location: NYC Posts: 939
IWSTI Addict since: Nov 2005 Trader Rating: (2) | i put it in open when it rains, heck i have it opened most of the times, very fun, rear wheel drive charaterictics with AWD traction FTW...also arent these f/r percentages only intial torque percentages??? |
| | #24 |
| Amateur STI Driver | i have an 07 limited... now imagine im a moron and if you can explain what you mean by "clamping down" and again, does open mean you have swithed to rwd as much as possible? im just not getting this whole dccd concept |
| | #25 |
| STI Driver | so if i wanted to do a tornado, a donut but start sitting still so the car doesnt actually move, it just spins like a monster truck, what would be the best setting to have it on? |
| | #26 | |
Try not to do this too much on dry pavement, and make sure not to crank your wheel all the way when you do. Not only is it unnecessary, but STi have very weak power steering pumps, and you will blow it up. | |
| | #27 |
| Professional STI Racer Car: 07 WRX STi Limited Fav Mod: Trunk Monkey Location: New York Posts: 611
IWSTI Addict since: Sep 2006 Trader Rating: (1) | For those of you who don't understand DCCD at all or need a better understanding, here is the link for you... http://wallace.as.arizona.edu/~cgrop.../DCCD_FAQ.html BTW, the 07 STis have a 45/55 split so that means less of a torque split to the rear for us |
| | #28 | |
| Silver Member | Quote:
oohhhh Yeah great reading... ^^ | |
| | #30 |
| IWSTI Club Level 1 Car: The Spaze Mobile Fav Mod: Tuning Location: South O.C., Ca Posts: 13,351
IWSTI Addict since: Jan 2006 Trader Rating: (5) | I am almost always in open mode at the track. But definitely not auto-x'n. This ad is not endorsed by this member. Please register or login to hide this ad. |
