Old 02-24-2004, 11:09 PM   #1
IWSTI Addict since: Feb 2004
I was thinking of going up to the bonnevile salt flats next month, and was wondering what the effects of running the car at 140 to 150 mph for long periods of time, say 10-15 minutes or more.
Will the STI be able to handle it, should i change the tires?
Im sure it will be ok, just wondering if there is anything i should know, i also want to go to some of the more empty highways around utah like highway 6.
thanks
Georgesti1 is offline   Reply With Quote
Old 02-24-2004, 11:31 PM   #2
IWSTI Addict since: Nov 2003
Default The Neons are coming, the Neons are coming!!!!
I broke in my car in 1 week. After that I drove it from Santa clara, ca to seattle, WA. hahha I was there for work and was gonna be there for a month...I just had to fly back and drive mah new car........i only had it for 2 weeks prior to that business trip.
I drove pretty much at 95 all the way
no probs here
GameOver is offline   Reply With Quote
Old 02-25-2004, 06:58 AM   #3
IWSTI Addict since: Sep 2001
Engine will be fine.
MrSwede is offline   Reply With Quote
Old 02-25-2004, 07:57 AM   #4
Fav Mod: stockboy
IWSTI Addict since: Sep 2003
check all your fluids before heading out and keep an eye on your temperture gauge to make sure you're not overheating. maybe even do an oil change before hitting the salt. definately talk to other "salt racers" to get thier opinions. Salt flats are so cool and i am envious.
crashsti is offline   Reply With Quote
Old 02-25-2004, 09:22 AM   #5
Fav Mod: La Quarta Stella
thanks
I would probably want an oil temp gauge and/or oil pressure just because I am paranoid.
What are the temps going to be? You might consider running a different weight oil based on weather.
-st
Singletrack is offline   Reply With Quote
Old 02-25-2004, 09:30 AM   #6
mistkerl
Guest
Posts: n/a
Default How to install strut tops?
Make sure your tires are pressurised appropriately beforehand.
You will be about 1500 rpm's shy of redline in 6th at that speed, so your motor should be fine, but you will hear a crazy howl after about 135, so don't freak out,
Old 02-25-2004, 10:37 AM   #7
thanks for the feedback guys, this should be really fun, i think first i may go to Joshua tree and try my hand at some rally driving, lots of good dirt roads out there. Im thinking ill get some cheap used all season tires from the WRX, anyone know of a good place to look?
Old 02-25-2004, 04:13 PM   #8
Ive heard about this howl but my car has never done that....let me explain this: I used to take it every now and then to 140 without hearing anything then one day from approx 117 to 125, more like 120, I started hearing a loud whinning noise comming from the rear right side of the car. Got home safely and inspected the rear right tire for a nail....YUP I had a nail in it. Next day I took care of that and just for expeimental purposes I drove between 115 and 130....whinning was still there....could it be an imperfection in the tires surface caused by the nail repair ???
thanks
Old 02-25-2004, 08:57 PM   #9
Default Do 02-03 WRX strut bars fit 04 STi ?
Check out www.scta-bni.org
The people running the salt flats have VERY strict Rules.
Bin there, not done that. Do have a copy of the 2000 year rules and have read them...
Web_Foot_STi is offline   Reply With Quote
Old 02-26-2004, 12:21 AM   #10
Car: Motorcycles
Fav Mod: Student
IWSTI Addict since: Oct 2003
Two things:
1) The car won't overheat - it'll run cooler than normal. As you pick up speed in higher gears the extra air flow to the engine more than compensates for the extra RPM the engine is pushing.
2) I already posted this in your other topic about tires, but you can't buy stock WRX tires - they're for 16 inch wheels, and the stockers on your STi are 17's.
bitabur is offline   Reply With Quote
