Old 11-03-2006, 05:16 PM   #1
Car: 94 supra
IWSTI Addict since: Aug 2006
Send a message via AIM to FlybySti5
no lights... center diff it feels like...theres only about 24k on the whole car. no diff fluid change... it has never done this in auto before thats the reason i ask..only in LOCK and the othre modes...if i can remember correctly....when would be a good time for diff fluids?
FlybySti5 is offline   Reply With Quote
Old 11-04-2006, 12:07 AM   #2
Car: 94 supra
Default Help DCCD!
I havent driven my car for about 2 weeks, when the dccd is set to auto and i turn wheel all the way left or right, or U-turn or anything, i get the "grinding" feeling in the diffs., like is at lock, when i turn the DCCD all the way down...i dont get the grinding....what could the problem be? I described it as best as i could...dont know how else to explain it...please help...thanks guys!
Old 11-04-2006, 12:34 AM   #3
Car: '04.5 STi
IWSTI Addict since: Apr 2006
Any dummy lights lit up? Where is the grinding coming from?
Old 11-04-2006, 12:39 AM   #4
Car: 05 Black on Black
IWSTI Addict since: Oct 2004
First off you have to understand that when you make sharp turns, your front wheels turn faster than your rear, and your outside wheels turn faster than your inside...meaning that your front outside wheel is turning alot faster than your inside rear wheel. My only guess would be that when your in autu mode, since the car can't realize your turning, it thinks a wheel is slipping, and tightens up the differential..thats when you hear the grinding. I believe it says something to that nature in the owners manual.
When the knob is all the way back, then the car doesn't try to tighten up the differentials.
DoubleURX is offline   Reply With Quote
Old 11-04-2006, 01:28 AM   #5
Car: 06 subaru wrx sti
Fav Mod: royal purple
IWSTI Addict since: Jul 2006
^for u turns and slow turns put all the way down.
disturbed1 is offline   Reply With Quote
Old 11-04-2006, 01:57 AM   #6
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
IWSTI Addict since: Oct 2005
Send a message via AIM to 520
Yah, its normal I beileve, for slow tight turns throw it into rear. A fluid change reduces this I have heard. How many miles since the last diff fluid change?
