Old 10-27-2006, 05:53 AM   #1
IWSTI Addict since: Mar 2006
Default Help- axle pulled out of differential (pics)
Last night I replaced a stripped camber bolt (note: either 127ft-lbs is a bit ambitious for the factory camber bolt, or I need a new torque wrench), and upon finishing I noticed a puddle of oil under the car.
This morning, when daylight presented itself again, I found the passenger's side CV joint pulled out of the front differential, exposing part of the axle I don't think I should be seeing. No oil has leaked since putting the strut back together last night, so either I lost that much oil (I'd estimate a cup, or 1/4 quart) or the thing is sealed again. The driver's side is fine.
I've never done any tranny work before, it's supposed to rain in a few hours, and it's freakin' cold outside. Is there a quick way to fix this? Am I missing a part that keeps the assembly held together?
Thanks for any quick help, guys. I'm about to begin exploring the service manual, but they can be a bit obtuse at times.
Old 10-27-2006, 06:28 AM   #2
This is the best instruction I have found so far in the service manual, and it's not very helpful.
Old 10-27-2006, 08:18 AM   #3
Car: 06 cgm sti w/ppg dog
Fav Mod: RIP 04 psm sti
IWSTI Addict since: Sep 2003
Send a message via AIM to nhsilversti Send a message via Yahoo to nhsilversti
grab it and give it a quick hard shove back in there, check that the c-clip is engauged by then pulling on the cv joint by hand. if it does not come out, it is locked in and if it does repeat the above process
ted
nhsilversti is offline   Reply With Quote
Old 10-27-2006, 09:07 AM   #4
I just got back inside from doing just that. Pushing on it just seemed so... simple.
I couldn't pull it back out again easily, but then again I needed the leverage of pushing on the brake rotor to push it in. I don't see a C-clip- should I? (I can't see one on either side of the car, so I'm guessing it is hidden.)
I completely unmounted the strut top and bottom to make sure I could give it a good shove without it impeding my range of motion.
Anyway, is that it? I guess it's time to change the tranny fluid. Thanks for your help!
Old 10-27-2006, 12:51 PM   #5
the c-clip is at the end of the axle, middle of the front diff, you wont be able to see it.
usually you have to use a quick sharp movement to lock it in. im willing to bet it is not locked in by the way you described it. even with the strut removed the rotor will not move enough to lock it in, unless you also released the lower ball joint.
Old 10-27-2006, 01:27 PM   #6
If it is pressed in all the way, would it not have to be locked? I can't press it in any further.
I guess I'll take a closer look. Thanks again.
Old 10-27-2006, 05:58 PM   #7
Car: 05 Subaru WRX STi
Fav Mod: RCE T2 Coilovers
IWSTI Addict since: Jun 2005
Trader Rating: (21)
Send a message via AIM to AndrewSS
Hehe, my axle pulled out once when my struts were pulled for camber plates, the problem with my strano bar is that it tensioned the hub so much that it flew outward pretty bad, what we didnt know is it pulled the axle out.
My friend just shoved it back in place and it was all good, except the huge mess of trans fluid all over the place (I lost more than 1/4qt, cause I backed it onto an incline before we knew what happened.
Anyway, I guess you sorted it out?
AndrewSS is offline   Reply With Quote
Old 10-27-2006, 08:33 PM   #8
Fav Mod: Forged Bypass
IWSTI Addict since: Feb 2006
Send a message via AIM to ilami01 Send a message via Yahoo to ilami01
Waranty!!!!!!!!! Dont Touch It......
ilami01 is offline   Reply With Quote
Old 10-28-2006, 04:39 AM   #9
Same thing here, except it was the Whiteline bar! I had both sides jacked up, then I lowered the other side again so I could break the lug nuts (forgot to to that before jacking).
I'm still waiting for dry weather so I can finish. It's been pouring since yesterday. Right now the car sits half way through a tranny oil change- that's where I was when the rain hit. I wish I had a garage!
nhsilversti has me worried that I don't have the axle locked into place yet- it's in all the way, but I didn't feel it snap into place.
Edit: it's not in all the way. Damn.
Old 10-28-2006, 06:44 PM   #10
like i had said, you need a FIRM QUICK SHOVE to get it to lock in. pushing on the rotor will not do it. you will not "feel" the snap either. do what post 3 says.
Old 11-30-2006, 07:57 PM   #11
Car: 200? WRX STI
Fav Mod: Super EX/RM-01A
IWSTI Addict since: Nov 2005
Send a message via AIM to o2sys
STI axels have spring pins? like in post 2?
o2sys is offline   Reply With Quote
Old 11-30-2006, 08:18 PM   #12
Super Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IWSTI Addict since: Apr 2006
I had this same thing happen to me on my old crx, going downhill on a sheet of ice. It takes a pretty good shove to get those clips to engage...
Old 11-30-2006, 09:55 PM   #13
Car: 05 STi WRB
Fav Mod: Driver's school
IWSTI Addict since: Jan 2006
Send a message via AIM to Splash Send a message via Yahoo to Splash
Yeah, I'm the one who re-engaged andrew's axle... I figured a quick snap is what unseated it, that's what it would take to re-seat it.
So that's what I did, pull back a little, shove in as quickly as possible, and that seemed to do the trick. I couldn't pull it back out after that so I figured it was ok.
Now, cleaning up 2 quarts of gear oil that ran down a 12-degree driveway wasn't near as simple... <grin>
Splash is offline   Reply With Quote
Old 12-01-2006, 12:00 AM   #14
Trader Rating: (21)
^ hehe, gracias... yeah about that oil!!! :eek!:
Old 12-01-2006, 08:50 AM   #15
Car: 05 WRB STi
Fav Mod: PWT Points
IWSTI Addict since: Dec 2004
on a similar note, I had my front driver axle pop loose when I was doing my coilover install and didn't notice until I had already pulled the car onto the street and heard some f*d up noises. Drove back to the garage - a pool of fluid. Had the dealership push it back in, but they tried to tell me the loose axle destroyed my center diff and I needed to replace it (a pretty penny I might add). Declined that work and still haven't noticed a problem after almost two years - is there even a potential for a problem after driving with a loose axle for about five miles?
