| Professional STI Racer Car: 06 Subaru WRX STI Location: Hurst, TX Posts: 716
IWSTI Addict since: Jun 2006 Trader Rating: (1) | Hello all, I think i my first mod for the STI is going to be a a short throw shifter. The most common recommendation seems to be either the Kartboy shifter with the bushings or getting the TiC supershifter set. I wanted to ask you guys if there are any other options which is should consider here. I found some stuff by Perrin, Cobb and this one Agency Power. http://www.vividracing.com/catalog/p...oducts_id/6719 I am trying to find out as much as i can about the performance of the other shifters but any input from you guys would be greatly appreciated !!! Also, with the TiC Super shifter set, do i need to worry about affecting the NVH levels in the car? I drive about 60 miles everyday so that is a big consideration for me. Hope this is the right forum for the thread. Thank you all This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| this space for rent Car: 04 psm sti Fav Mod: custom 03 seats Location: california Posts: 742
IWSTI Addict since: Jul 2006 Trader Rating: (8) | i have the cobb shifter with the kartboy front and rear bushings and it is a great mod, you will love it..as far as the noise level its minimal go for it |
| | #3 |
| 1B4DSTI
Car: 06 CGM/Emotions Fav Mod: M&J Modified Location: Bensalem, PA Posts: 7,249
IWSTI Addict since: Jan 2006 Trader Rating: (10) | karyboy SS ius good |
| | #5 |
| Silver Member
Car: 06 STI CGM Fav Mod: Stereo Location: Napa, CA Posts: 607
IWSTI Addict since: Nov 2005 Trader Rating: (7) | I love my COBB double adjustable... you can pick how high you want it as well as how short of throw you want. I don't think any of the others are adjustable. The urethane front bushing added a bit of noise. I even went so far as to use sound deadener on mine |
| | #6 |
| S204 Racer Car: 2005 White/Gold STi Fav Mod: TD06-20G/Tein Flex coilovers Location: New York Posts: 2,888
IWSTI Addict since: May 2005 Trader Rating: (8) | I highly recommend the TIC "super shifter" kit. It's the Kartboy lever with all the replacement bushings you'll need. The only NVH that i've experienced is increased gear whine, but it sounds cool to me and you get used to it quick ![]() Also, the little bit of extra noise is well worth it. Everything is rock solid with the kit installed and the throws are much shorter |
| | #7 | |
IWSTI Addict since: Jun 2006 Trader Rating: (1) | Quote:
| | #10 | |
Also, does the stock STI shift knob fit on the Kartboy shifter ? | |
| | #12 | |
| The Next Petter Solberg Car: 06 AW STI Fav Mod: Hardwired 8500 Location: Boulder, CO Posts: 968
IWSTI Addict since: Feb 2005 Trader Rating: (1) | Quote:
def. the coolest abilities. adjust height and throw is sick. | |
| | #15 |
| Platinum Member Car: 06 STI UGM Fav Mod: (o)(o) Location: Kelowna Posts: 1,141
IWSTI Addict since: Jul 2006 Trader Rating: (0) | Whats the diff between the stock short throw and these aftermarket ones? All 06 come with short throw stock so why change? Jay This ad is not endorsed by this member. Please register or login to hide this ad. |
