| Spec C Club
Car: 04' WRB STi Fav Mod: TBE Location: Allentown, PA Posts: 1,646
IWSTI Addict since: Sep 2006 Trader Rating: (1) | Does anyone else's shifter have play in it while its in gear? Mine does it in every gear. I can move it about 1 inch left to right while its in gear. Shifter bushings? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| STI Driver Car: 04 STi - Aspen White Fav Mod: Cobb Short Shifter Location: Atlanta, GA Posts: 289
IWSTI Addict since: Apr 2006 Trader Rating: (0) | bushings would be my guess. i replaced mine with the ones from Cobb when i put the short shifter in and there's virtually no play when in gear. |
| | #4 |
| The Hoff Fan Club, member #001 Car: 05 WRB/Gold Fav Mod: Hood Scoop Homer Location: Where ever The Hoff is! Posts: 10,365
IWSTI Addict since: Jul 2004 Trader Rating: (4) | basically every stock sti shifter i've ever tried does this. Check out turninconcepts.com and you can pick up some of their bushings. |
| | #6 | |
| STI Driver | Quote:
Anyway, bushings make such a difference in the shifter. Replace all the shifter bushings and it will be so precise, you will love it. | |
| | #7 |
| Grassroots STI Racer | I have the KartBoy bushings and TiC bushings - does anyone else get a vibration noise because of the rigidity of the bushings transmitting vibrations up the shifter? I hate it, I have to turn the radio up. |
| | #8 |
| Spec C Club Car: 04 WRB STi Fav Mod: JDM STi Recaros Location: ABQ/PDX Posts: 1,183
IWSTI Addict since: Jun 2006 Trader Rating: (0) | I had a ton of slop, installed Kartboy Front and Rear shifter bushings, and... still the same slop, just slightly more precise changes. I think I'm going to try pivot and u-joint bushings next. |
| | #9 | |
| Amateur STI Driver | Quote:
| | #13 | |
| Silver Member
Car: 2004 WRB STi Location: Atlanta,GA Posts: 2,066
IWSTI Addict since: Aug 2006 Trader Rating: (14) | Quote:
![]() Each gear clicks in literarally, so you are 100% sure you are in gear or not, no more vauge feeling This ad is not endorsed by this member. Please register or login to hide this ad. | |
