| | #106 |
| Spec C Club Car: 06 white w/gold STi Fav Mod: gt40r Location: Orange, CA Posts: 1,223
IWSTI Addict since: Apr 2005 Trader Rating: (6) | Rootus owes me LUNCH...YES! This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #107 |
| Senior STI Driver Car: 2005 Subaru STi Fav Mod: Cobb Swaybars and Kartboy Endlinks Location: Minnesota Posts: 351
IWSTI Addict since: Oct 2005 Trader Rating: (1) | For what it's worth... after the new DS I'm always wanting to shift into 6th - I'm already in 6th, its just that the pull seems like I'm in 5th... weird, but I'll guess I'll have to get used to it... |
| | #108 |
| Amateur STI Driver | i just got my d/s installed. there is a difference in performance but i think it is not so much as some have noticed. Perhaps you guys (USDM sti) have a heavier stock d/s. Maybe you should start buying and modifying some stock EDM sti driveshafts! I can give you the part number for the companion flange that you need. I will weigh my d/s to see how heavy it is. the acpt feels lighter but not by much. No vibration at all up to 120mph. it's a good mod but i am not sure it is worth the $$$ on the EDM sti. but this is just an unjustified opinion until i weigh my stock d/s. |
| | #109 | |
| The Next Petter Solberg Car: 08 Z06 Corvette Fav Mod: Jack Jack Location: Portland, OR Posts: 882
IWSTI Addict since: Oct 2005 Trader Rating: (3) | Quote:
Clearly alot changed between the two dynos, and you are submitting that the only difference was the driveshaft (not the weather, barometer, etc). Wow.. so then the new DS lost you some spool... and gained you nearly 40lbft of torque in some places. Thats amazing......... | |
| | #110 | |
| Gold Member Car: 06 cgm sti w/ppg dog Fav Mod: RIP 04 psm sti Location: southern nh Posts: 449
IWSTI Addict since: Sep 2003 Trader Rating: (0) | Quote:
you should get ahold of franz diebold automotive and confirm for yourself that it is the same WOT tune. as i had stated, there were drivability changes made at low/part throttle, nothing drastic or that would affect the WOT part. yes there was a few months between the 2 graphs but, here in new england may and october are about the same for weather. ted ps. you start pulls at 2k or lower for bigger turbos? interesting imo | |
| | #112 |
| STI Driver | "The change in mass of the driveshaft is so close to the axis about which it spins... is so trivial that physics just doesnt seem to back up the claims." Don't be so sure. For one the stock DS has a 2 degree bend in the center, more under load; how do you account for this with the "radius" argument? How much power is lost just going thru this joint? And don't forget this loss is before another gear box and two more CV joints; are losses fixed amounts or are they multiples? The CF shaft is half the weight, roughly 12 lbs, and trust me - you feel it. You feel all 200lbs! I've written about the benefits before, so let me just say - when I get a new car I will pay ACPT to build me a carbon DS, no matter what it costs. |
| | #113 | |
| Spec C Club
Car: 07 STI LTD/08 STI Fav Mod: APS/Crawford/Cosworth/Aquamist Location: E-town, AB Posts: 2,373
IWSTI Addict since: Apr 2005 Trader Rating: (5) | Quote:
![]() It better. | |
| | #117 |
| Spec C Club
Car: 05 WRX STI - Spec A Fav Mod: Starving my STI Location: Lightweightville, Canada Posts: 1,734
IWSTI Addict since: Sep 2006 Trader Rating: (15) | Regarding my vibration problem between 165-175 km/h ----------------------------------------------------- Ok I finally got down there. I took off the DS protection plate, so it could not rub that, but guess what? It was rubbing on the thing ABOVE it... there is a tiny ring there... but it's not even deep at all... like maybe 0.25mm... very very minor scuff... that is why the vibration has been getting less and less... in fact, it is pretty much non-existent now... I guess the resonance at that speed (about 170 km/h = 105 mph) causes the shaft to "bow" and slightly hit the mounting area for the diff. I doubt it's out of balance... my understanding is that if it's out of balance, the vibration gets worse with speed. Problem is, I don't think there is anything I can do about something like this short of GRINDING that area and painting it... which is what I will probably do. |
| | #118 |
| Amateur STI Driver | i weighted my stock EDM sti d/s. it is 20.9 lbs which is about 5 lbs less than the stock USMD d/s so maybe you guys should consider buying and modifying EDM d/s for some weight savings. my acpt is still 7.5 lbs lighter but you guys need the acpt much more than people with EDM or JDM driveshafts. |
| | #119 | |
| Silver Member
Car: 05 Subaru WRX STi Fav Mod: DB 20G, Diamond Black BBS RE's, S2K retrofit Location: NY Posts: 4,631
IWSTI Addict since: Jul 2004 Trader Rating: (7) | Quote:
| | #120 |
| Amateur STI Driver | no it requires some redrilling of the rear diff companion flange. the usdm sti has a different bolt pattern on the d/s This ad is not endorsed by this member. Please register or login to hide this ad. |
