Old 10-11-2006, 12:33 PM   #61
Car: 06 white w/gold STi
Fav Mod: gt40r
Send a message via AIM to Blaiser
Originally Posted by Rootus
I'd bet lunch a dyno test shows no difference. Changing the amount of rotating mass does not change the amount of power that actually gets to the ground, it simply reduces the amount of mass the engine has to accelerate. It would be like taking 50 pounds off the car and trying to measure that on a dyno . If you had a very, very heavy driveline, lightening it up significantly might change the dynosplot slightly by allowing torque increases to show slightly earlier. The amount of weight lost with a CF driveshaft is unlikely to show up as something identifiable.
I'll take that bet
i understand what you are talking about, but to me it only makes sense that this would increase hp and torque to the wheels....why wouldnt it, isnt that the purpose if this mod? the company claims 5% more hp on the whole curve...but no one has tested it, i would really like to see someone test this before i would consider buying it.
Also...people compare it to a TBE, that adds WHP...it has to add something is what im saying.
So, where do you live...when this is tested i want my lunch
Blaiser is offline   Reply With Quote
Old 10-11-2006, 01:15 PM   #62
ACPT will be dyno testing one of these shafts here in a week or two, wo we will see who will owe who a lunch.
grim09 is offline   Reply With Quote
Old 10-12-2006, 05:43 AM   #63
Car: '04.5 STi
Fav Mod: ZZYZX
If there weren't so many people saying this thing made such a difference, I don't think I'd believe it. I guess I just don't understand how eliminating weight from certain parts of the drivetrain affects acceleration, and I certainly don't understand how changing a part that's behind the transmission can make shifting and throttle response better.
I can see how it could make a noticeable difference in the lower gears where the driveshaft isn't spinning very fast. But in the upper gears it takes less effort to get a heavy spinning object to spin faster, so it really confuses me to read that people are saying that it makes a large difference in 4-6.
Old 10-12-2006, 06:12 AM   #64
Fav Mod: T2s and Recaros
I'll take that bet!
Reducing rotating mass from the drivetrain will allow for less horsepower to be lost driving the shaft, which means more power at the wheels. I've seen the benefit of lighter driveshafts doing just this on other cars.
So when the dyno shows a gain, wheres lunch going to be at?
Old 10-12-2006, 06:41 AM   #65
The upper gears don't have the torque multiplication that the lower gears do, so the engine has to work harder to maintain speed+higher amount of friction from air resistance, etc. It makes sense that people would feel a larger gain in the higher gears due to this, IMO since the gearbox isn't giving the engine as much help.
Old 10-12-2006, 06:46 AM   #66
Car: '04.5 STi
Fav Mod: ZZYZX
hmm, I hadn't thought about that trade-off...
Has anybody done a "before and after" drag strip run to test for an improvement in acceleration?
Old 10-12-2006, 06:48 AM   #67
NIИja
someone used some sort of g-meter. that's all i know of. you'd have to dig for it.... I think it's towards the end of the orignal DS thread.
Old 10-12-2006, 06:52 AM   #68
Car: '04.5 STi
Fav Mod: ZZYZX
I'll have a look... but that thread is so large that it's almost useless.
Old 10-12-2006, 07:01 AM   #69
NIИja
it's towards the very end. i'll try to help you out.
Old 10-12-2006, 07:07 AM   #70
NIИja
ACPT carbon fiber driveshaft, Thread #1
Here you go.
Old 10-12-2006, 07:13 AM   #71
Car: '04.5 STi
Fav Mod: ZZYZX
Well, I'll keep this on the top of my list of things to buy. For power upgrades my car doesn't even have a downpipe, nor do I have an AccessPort. So maybe I'll just slot it in right after I do those upgrades.
Old 10-12-2006, 07:14 AM   #72
Car: 06 cgm sti w/ppg dog
Fav Mod: RIP 04 psm sti
Send a message via AIM to nhsilversti Send a message via Yahoo to nhsilversti
OR you could have read the OP in this thread......
nhsilversti is offline   Reply With Quote
Old 10-12-2006, 07:15 AM   #73
Car: '04.5 STi
Fav Mod: ZZYZX
Thanks.
Old 10-12-2006, 07:22 AM   #74
look at it a couple of ways
large heavy wheel and tire combos will decrease shown power on a dyno due to the power going into moving the heavy wheels. the power has to be used to FIRST get the wheel moving then it can use whats left to move the car.
a good old fashioned bicycle.....what can you pedal more easily(given same gear ratio is used)? a heavy fat tired clunker or a light weight skinny tire road bicycle.
the same principal applys to the drive shaft and the wheels (or any other rotating mass). if less power can be used to move the wheel, brake rotor or driveshaft then the power can be used to accelerate the car faster.
ted
Old 10-12-2006, 12:16 PM   #75
Fav Mod: gt40r
I Want My Lunch!
