Old 11-15-2008, 11:17 PM   #466
Car: 05 STi CGM Stg2
IWSTI Addict since: Apr 2006
Default Re: ACPT Carbon Fiber Driveshaft, Thread #2
Originally Posted by DeOppressoLibre View Post
How are these carbon fiber driveshafts in the winter as far as being affected by road muck and salt?
no worries here in ontario for 3 winters
Old 11-15-2008, 11:18 PM   #467
Originally Posted by Thejoyofdriving View Post
A few people have said that they go off roading and drive in the snow/mud with no problems.......however a few people are getting some rust on the exposed part of the yolk(?)
Thats surface rust not even Grade A rust. When it gets to grade C then you may want to worry wtf is going on but that wont happen with this steel
Old 11-16-2008, 12:34 AM   #468
Car: WRB 2005 STi
Fav Mod: Getting an STi
IWSTI Addict since: May 2008
Send a message via AIM to Thejoyofdriving
Well. Since the yolk gos in and out there was worry by a few people that the rust, however little there was, would get to the seal in that area and wear it out prematurely.
Thejoyofdriving is offline   Reply With Quote
Old 11-16-2008, 07:28 AM   #469
Car: 2007 WRB Blue STi
Fav Mod: COBB!
IWSTI Addict since: Mar 2008
Send a message via AIM to mond12345
But If i can remember correctly, i just a thread that someone had this problem... How can i do sure. Again if I'm going to send a grand on something, it better be right!
The first few batches had vibration problems. The new ones dont.
mond12345 is online now   Reply With Quote
Old 11-17-2008, 02:48 AM   #470
IWSTI Addict since: Aug 2003
got this machined to fit my Aus spec 03/04 STi today.
waxdass is offline   Reply With Quote
Old 11-18-2008, 12:24 AM   #471
Authorized JDM Vendor
Fav Mod: Anything JDM; well alot of stuff anyway
IWSTI Addict since: Nov 2005
Trader Rating: (23)
Make sure the front nose of the shaft engages to the same depth as stock. A small shim may or may not be necessary between the rear flanges to satisfy that requirement.
SoJDM.com is offline   Reply With Quote
Old 11-18-2008, 01:13 AM   #472
are you talking about the long piece of metal that slips into where the gear box is?
if so - that is comes short of the stocker.
Old 11-18-2008, 10:31 AM   #473
Trader Rating: (23)
That's the part I'm talking about. The length that is inserted into the transmission should be the same. Do not worry about the amount left exposed on the ACPT shaft vs. the stock shaft. The depth of engagement is the critical amount. Once this is established, you can check for the gap if any between the flanges.
Old 11-18-2008, 12:27 PM   #474
Fav Mod: COBB!
So are all the "new" shafts being delivered have no balance issues now? This is what is still basically holding me up!
Old 11-18-2008, 04:27 PM   #475
do you have a picture of the "shim" part your talking about?
does it mean I have to get the bracket re-machined again?
Old 11-19-2008, 11:38 AM   #476
Trader Rating: (23)
No, the shim would be just a round metal plate of the proper thickness inserted between the two flanges. It would look just like a section from one of one of the flanges. I have no picture because the customer did not send one but described it.
You may not need this at all. Check the engagement measurement to be sure.
Old 11-19-2008, 11:44 AM   #477
Trader Rating: (23)
There is not a balance issue. The shafts are all balanced before sale. My theory after selling a lot of the driveshafts and dealing with a few apparent balance problems is that on some vehicles there is a resonance problem. There is no rhyme or reason for which vehicle will sometimes exhibit this problem.
Old 11-19-2008, 04:37 PM   #478
so can I still run it without the shim for the time being?
it comes a bit short but will it still be ok?
Old 11-20-2008, 09:18 AM   #479
Trader Rating: (23)
I couldn't see it hurting if you have verified the required shim thickness is small.
Old 11-20-2008, 03:37 PM   #480
its about 1.5 inches shorter.
im driving around with it now - and it feels good - no vibrations at all under 100 km/h.
