Old 08-22-2007, 03:53 PM   #271
IWSTI Addict since: Feb 2006
Default Re: ACPT Carbon Fiber Driveshaft, Thread #2
[quote=MidniteTunez] I wonder how a light flywheel and the acpt drive shaft respond together... Sounds like theyd work together well..
QUOTE]
The combo is sweet! 1st and 2nd gear fly so fast you almost can't shift fast enough! I have also done about 175mph (after caluculating the rpm after the needle was buried) with the driveshaft in the car and no problems what so ever!
grim09 is offline   Reply With Quote
Old 08-22-2007, 04:19 PM   #272
Car: 06 sti
Fav Mod: invidia turbo back exhaust G200
IWSTI Addict since: Jun 2006
Originally Posted by MidniteTunez
Oh and one more note, for those who have a set rpm launch, stuttarbox, you will have to raise it higher with lighter drivetrain parts because remember now that the rpms drop faster than before therefore say you were launching at 6grand before, its going to fall to say 500rpms lower than before by the time it gets going due to less rotational inertia, therefore bumping the launch rev a little higher should equalize the rpms you take off at with your previous before acpt d/s settings.
On my awd dsm i had to increase the stuttarbox launch rpms from 5000, to 5500 to get the same kind of launch due to a light weight flywheel as an example.
if i am reading this correctly this only holds true (imo) with the flywheel and pullys. drive shaft, wheels, tires and rotors you should be able to set the rpm,s lower or leave leave the setting where it is.
gohrsepwr is offline   Reply With Quote
Old 08-24-2007, 07:49 AM   #273
Car: Blue 04 Wrx STi
IWSTI Addict since: Jul 2007
Send a message via AIM to MidniteTunez
I dont think pulleys are heavy enough to make much difference, I think its just anything that the engine has to rotate over x amount of weight that would be significant in rpms. I know with the lighter flywheel the launch revs have to be bumped up some. I cant imagin why a lighter driveshaft wouldnt cause the same effect. Maybe anyone with the acpt d/s can elaborate on this or tell us how their launching went before/ after the install.
MidniteTunez is offline   Reply With Quote
Old 08-24-2007, 08:03 AM   #274
Car: 06 WRB Sti
IWSTI Addict since: Aug 2006
Drive shaft will not be the same as it is behind the clutch. When you spin up the engine you are also spinning up the flywheel, this give you engine power + some rotating momentum to apply torque to the wheels when you let the clutch out. However since the drive shaft is not spinning at this point it's not helping or hindering you. Once you do launch though less power is being put into spinning up a heavy drive shaft and can be used to spin up the wheel speed = faster acceleration.
aus_taz is offline   Reply With Quote
Old 08-24-2007, 08:07 AM   #275
Fav Mod: Logitec G25 & Playseat
IWSTI Addict since: Jul 2006
The driveshaft won't make any difference on RPM to launch, pulleys and flywheels will. The reason that revs are raised is because there is less rotational inertia at the same speed with lighter components. Any lightened component on the engine side of the clutch will make a differnce in launching. On the other side ie. Trans,DCCD,driveshaft,diff will not effect anything since the clutch isn't engaged. Once it is ingaged you slip a little then totally engage (while at WOT) the other components simply allow you to accelerate faster.
Disclaimer:
I know that the things I listed do have an effect, but it would probably be unnoticed by almost all where as the flywheel and pulleys MAY be.
07WRBSTI is offline   Reply With Quote
Old 08-27-2007, 11:52 AM   #276
were can i order this ACPT driveshaft and also what is a good cluch kit and flywheel to get thanks
rmontheweb is offline   Reply With Quote
Old 08-27-2007, 09:01 PM   #277
Fav Mod: Track days!!!
IWSTI Addict since: Jun 2005
SoJDM and ImportImage (both vendors on here) each have a thread in the Vendor For Sale-Drivetrain section.
05cgm is offline   Reply With Quote
Old 08-28-2007, 10:24 AM   #278
Disclaimer:
I see, thanks... Makes sense. Didnt look at it that way.
Old 08-28-2007, 03:40 PM   #279
nulla poena sine lege
Car: '08 GT500
IWSTI Addict since: Nov 2003
ACT w/gruppe-s flywheel combo from gruppe-s.com
QuickSilverSTi is offline   Reply With Quote
Old 08-30-2007, 08:58 AM   #280
Fav Mod: me
IWSTI Addict since: Sep 2006
Hey stoney98,
The lower horsepower WRX's have a 5-speed tranny, so you need a different drive shaft. I saw that sojdm had them.
http://www.sojdm.com/store/pc/viewPr...8&idproduct=90
This is what you are looking for!
Treadwell is offline   Reply With Quote
Old 09-14-2007, 02:50 PM   #281
Car: 2007 Subaru Impreza
Fav Mod: Cobb AP
IWSTI Addict since: Aug 2007
Just had mine installed today, 30 mins is all it took. I can vouch for few improvements over stock unit: it revs faster, drives smoother, shifts easier. I took the car up to 105 going on ramp to make sure no vibration nor weird noises. I'm quite used to getting the speed up in it, but how it got up there boggled the mind, and because the car drove smoother, it was very hard to tell how fast the car was actually going until you looked at the speedometer.
All in all, I agree with lots of you who had this installed, not the best bang for the buck, but I think this is better than slapping big turbos on to a car, well, in a daily driveability kind of sense.
2MANYCARS is offline   Reply With Quote
Old 09-14-2007, 03:12 PM   #282
Fav Mod: ACPT driveshaft
IWSTI Addict since: Oct 2003
Glad you're enjoying it I thought the improved driveability was the best part - and any future performance mods will be that much more effective with the CF DS.
HarlanPepper is offline   Reply With Quote
Old 09-14-2007, 03:53 PM   #283
Trader Rating: (14)
okay, someone needs to sell me a used unit
Old 09-14-2007, 04:04 PM   #284
Muller Chevrolet
Fav Mod: beastly fenders
IWSTI Addict since: Oct 2004
yea me 2!
Old 09-14-2007, 05:10 PM   #285
Car: '08 AW STI
Fav Mod: Bobble-Free
IWSTI Addict since: Mar 2006
PM me an offer!
trippin is offline   Reply With Quote
