| | #151 | |
| STI Driver | Quote:
Unfortunetly Rainmaker, I just dynoed that WRX yesterday with a before and after of the ACPT carbon fiber driveshaft and there was a significant gain in the midrange and at the top of the RPM range. Basiclly, he was able to acheive max horsepower a couple thousand RPM sooner than before and although it does not change your peak horsepower or torque, the car showed about a 5% increase across the graph. At the top it was a 16 whp difference. This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by grim09; 01-10-2007 at 07:37 AM. | |
| | #152 |
| Professional STI Driver | I don't even see how people are arguing against this driveshaft. Lighter rotating drineline mass = better. PERIOD! The engine doesn't have to use as much power to spin a lighter object; that power can then be used elsewhere ie: to accelerate the car. Whether this power shows up on the dyno screen or not is irrelevent because the power and extra acceleration are there whether any wants to believe it or not. You can't argue with physics. |
| | #154 | |
| Silver Member Car: 05 WRB STi Fav Mod: PWT Points Location: St. Louis, MO Posts: 980
IWSTI Addict since: Dec 2004 Trader Rating: (2) | Quote:
| | #155 | |
| The Next Petter Solberg Car: 08 Z06 Corvette Fav Mod: Jack Jack Location: Portland, OR Posts: 882
IWSTI Addict since: Oct 2005 Trader Rating: (3) | Quote:
Right? | |
| | #156 |
| Spec C Club Car: '04 WRB Fav Mod: A working ECU... Location: CT Posts: 1,485
IWSTI Addict since: May 2003 Trader Rating: (7) | I don't have time to read the whole thread, but here's my results from some time ago, posted in previous carbon DS threads... http://www.iwsti.com/forums/attachme...5&d=1161714992 Here's my dyno comparison of carbon fiber vs. stock driveshaft. This is back when I was AP stage 2; same dyno, about 2 weeks apart (Nov '05). I had posted the results in the original driveshaft thread, but they got buried quickly. Peak gains are about 9 ft-lbs. and 5 WHP. Last edited by ValvetrainEngineer; 01-10-2007 at 09:54 AM. |
| | #157 | |
For the <10fllb and <13awhp I *expect* it to really make, I'd be willing to pay .............ehhh...........$400. But it's not.... it's $1100+ I think alot of folks spend the $1100 based on posts of personal revolution, and then when they get it, they work hard to justify their $1100 expediture to themselves. Chris | |
| | #158 | |
IWSTI Addict since: May 2003 Trader Rating: (7) | Quote:
And the benefit isn't just power - need to consider the lower weight effect on braking and handling (again small, but adds up). That being said, I'm a big fan and would do it again! | |
| | #159 | |
Exactly what I would expect, and exactly what physics theorizes should happen. thanks, Chris | |
| | #160 |
| Professional STI Racer
Car: 2004 Audi S4 Avant Fav Mod: wheels & suspension Location: Normal, IL Posts: 746
IWSTI Addict since: Oct 2004 Trader Rating: (5) | So if I do a lightened pulley and a CF driveshaft at the same time I'm guessing this should definitely be something to feel "in the seat of the pants".... |
| | #161 | |
| Senior STI Driver Car: '06 SubaruImprezaSTi Fav Mod: Full-Race exhaust manifold, ACPT CF Driveshaft Location: Everett, WA Posts: 326
IWSTI Addict since: Feb 2006 Trader Rating: (1) | Quote:
| | #162 |
IWSTI Addict since: Dec 2004 Trader Rating: (2) | I really want the cf driveshaft to compliment my flywheel. I can't even imagine what its going to feel like with the loss in weight on a cf driveshaft, prolite flywheel, 2 piece front rotors. Still debating the idea of a pulley - but have never been too fond of them. Just have to save a grand now =) |
| | #163 |
| Silver Member
Car: 05 Subaru WRX STi Fav Mod: DB 20G, Diamond Black BBS RE's, S2K retrofit Location: NY Posts: 4,653
IWSTI Addict since: Jul 2004 Trader Rating: (7) | How much longer are these out of stock for? |
| | #164 | |
| STI Driver | Quote:
| | #165 |
| Professional STI Driver | Have any of you checked out the recent aluminum DS thread? Seams interesting. If it turns out to be built well then it might be a good solution for those that can't justify $1000+ for the CF one. The DS costs around $500 and it is even a lb or two lighter than the CF one. Installed my aluminum driveshaft! (update post #34) This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by mtskibum16; 01-10-2007 at 12:21 PM. |
