Old 08-18-2006, 06:46 PM   #46
Car: 2008 Fitrari Red
Fav Mod: Getting 40mpg
IWSTI Addict since: Jan 2004
Mine were also a byatch, so I resorted to using a long bolt and fender washers to squeeze it all together.
Stee is offline   Reply With Quote
Old 08-18-2006, 07:51 PM   #47
The next Sebastien Loeb
Fav Mod: Super Low Friction Brake Pads
IWSTI Addict since: Apr 2006
Trader Rating: (24)
Is everyone that is having problems doing this on the stock shifter?
Sounds like it. Or also maybe the Kartboy SS.
OT: Hey TiC!! When are you getting these back in stock?!!?! I am going to order a crapload of bushings/parts from you as soon as you get these in!!!
Old 08-19-2006, 11:48 AM   #48
Car: '04 silver sti
Fav Mod: ap
IWSTI Addict since: Oct 2003
Yea,it seems that those of us with the stock shifter have the most probs. Clint mentioned that they did the early fittings of these on a kartboy short.One other thing I did while I was in the console was to move the roller switch for the dccd.I trimmed some of the flexiable covering and some of the electrical tape from the wire bundle and mounted the switch next to the on-off button up by the hand brake.The cover that was there fits right into the space were the switch was.
tugz is offline   Reply With Quote
Old 08-19-2006, 12:02 PM   #49
Shamwow Vince is my hero
Car: AW GDF-D
Fav Mod: Q-Rack
IWSTI Addict since: Oct 2005
Trader Rating: (12)
I just finished mine. It took me longer to extract the stock bushings than to install the new ones.
COBB double adj. short shifter FTW!
Old 08-19-2006, 12:03 PM   #50
Trader Rating: (24)
you have an 04 i presume. sounds like a good idea. lets see pics.
Old 08-19-2006, 12:05 PM   #51
Car: AW GDF-D
Fav Mod: Q-Rack
Trader Rating: (12)
oh- i did this btw. i just added washers on each side of the greased up busings and slowly used the stock nut/bolt to tighten them into place.
Old 08-19-2006, 03:16 PM   #52
Moderator Elite
Car: 04 Subaru WRX STi, W
Fav Mod: KartBoy SS & Bushings
IWSTI Addict since: Jan 2001
Send a message via AIM to MKIVSupra Send a message via Yahoo to MKIVSupra Send a message via Skype™ to MKIVSupra
I just installed mine. It was very easy. I was able to push it most of the way in by hand and finished it off with a c-clamp. The only weird issue I had was that I was not able to torque the bolt to 8 ft lbs. I mean, I was able to, but it was way to tight. I tried it a couple times and got the same result. I ended up doing it by how the shifting felt. Unless my torque wrench is f'ed up, which I doubt, I don't know why this would happen since it worked with the stock bushings when I installed the KB SS.
MKIVSupra is offline   Reply With Quote
Old 08-19-2006, 03:48 PM   #53
Wes
I'm Jim Halpert
Fav Mod: EWG
i was told that its 8 lbs MAX so what u did was right. doing it by hand and tightening it as much as u like it
Wes is offline   Reply With Quote
Old 08-21-2006, 05:08 PM   #54
Car: 05 CGM STi
Fav Mod: Topspeed tune
I just installed mine this evening in my Kartboy short shifter and it was really pissing me off. I grabbed a couple of big washers that I had and used those in conjunction with the stock nut and bolt and squeezed them together. For those of you using this method make sure you tighten the nut until you can't tighten it any more with reasonable force (I didn't at first because I was afraid to split the bushing and it kept backing out when I loosened the nut). Voila! Bushing will be seated with no marring of the face.
revnup is offline   Reply With Quote
Old 08-25-2006, 02:25 AM   #55
Car: AW 05 WRX STi
Fav Mod: Recaro Racing Seats
IWSTI Addict since: Sep 2004
Send a message via AIM to JKonquer Send a message via MSN to JKonquer
i installed mine last weekend, it had to be the one of the easiest install i've done in my car, EVER! it took me 15 mins.
just used flat head to take off the existing bushing and greased up the new ones with lithium grease, gave couple banging with the hammer and it was IN!
i torque wrench only go down to 10lb, so i just hands feeling to do it. first time was way too stiff so i loosen up a little,but it was too soft. so i just play with it couple times and just got it to way i like it.
i love this thing, TIC SS kit with this bushing really fiinshed off my shifter.
hey clint, you should include pivot bushing on your SS kit! thanks by the way
oh yeah and thanks for the airplane, my cousin's been playing with it all night. lol
JKonquer is offline   Reply With Quote
Old 08-25-2006, 08:42 AM   #56
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (54)
Actaully, we're going to. We're waiting for more to come in before we can put the updated SSS on the site.
Turninconcepts.com is online now   Reply With Quote
Old 08-25-2006, 09:47 PM   #57
Trader Rating: (54)
Check it now.
Old 08-25-2006, 11:19 PM   #58
Car: AW 05 WRX STi
nice! just wondering, is there any meaning behind the toys you send out with parts?
Old 08-29-2006, 02:03 PM   #59
Wes
I'm Jim Halpert
Fav Mod: EWG
i just installed the bushings and the factory ones were actually harder to get out than it was to get the new ones in? is that supposed to be that way? i thought it was supposed to be really tight. but it does still feel like a more gated feel.
Old 08-29-2006, 02:41 PM   #60
Trader Rating: (54)
Yes. It means go and play with them and have fun.
