| | #16 |
| Senior STI Driver Car: 05 CGM STi Location: Southeastern PA Posts: 355
IWSTI Addict since: Jun 2005 Trader Rating: (0) | I have the EPC, so I figured I'd check. There are 2 diff. part numbers. 32650 AA120 fits 04,05 and 06's to 12/16/05 32650 AA150 fits 06's from 12/17/05. It appears that they are not interchangable either. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #17 |
| Junior STI Driver Car: O4 WRB STi, 91 GSX Fav Mod: SH0CKER License plate Location: Butler, PA Posts: 135
IWSTI Addict since: Jan 2003 Trader Rating: (4) | I did two track days last week and started have a little crunch from 5th to 4th. At like 8k I had my tranny pulled to replace the synchros and that was adult daily driven usage. I just hope the new fluid helps I was thinking it is broken down fron the heat etc. But worst case hopefully they will replace under warranty and maybe I can get them to put this in instead of USDM OEM replacement. This is what I may get: RST-1145kit JDM Upgrade Kit for STi 6-spd. $450 Upgrade kit for the US STi 6-speed gearbox includes short ratio 5th and 6th gears, uprated carbon-reinforced 4th, 5th, and 6th gear synchro rings, and a new 5th/6th gear synchro hub set. Helps to eliminate 4th, 5th, or 6th gear grinding issues due to premature synchro ring wear. Matt |
| | #18 |
| Junior STI Driver Car: 04 sti/08 335xi. Fav Mod: doug topspeed Location: spartanburg, sc Posts: 178
IWSTI Addict since: May 2006 Trader Rating: (1) | from what i know rallispec has the best price and they are good with costumer service. I got the synchros from the kit you are referring to but didnt want the gears. i want to still have the highway car that i have now. those gears will from what i hear lower gas mileage at highway speeds pretty bad. also from what i hear if you have synchro problems all you really need to replace are the actual synchros. the hubs and sleeves very rarely go bad. if i were you i would do what im doing and just buy the 4,5 and 6 gear synchros for $75. |
| | #19 |
| Junior STI Driver | the 06 indeed has different 5th & 6th synchro's. If you want to problem to mostly go away, use the JDM 5th & 6th gears, the new synchro's, a tranny cooler (if you track the car) and the factory fill... Ray This ad is not endorsed by this member. Please register or login to hide this ad. |
