| | #16 |
| Professional STI Racer Car: 05 STi OBP Fav Mod: Data Acq System Location: Warren, Michigan Posts: 798
IWSTI Addict since: Jul 2006 Trader Rating: (1) | Bruce, where do you get your Motul FF Comp from?? That stuff doesn't look cheap at all so I was wondering ifi you got a hook up spot?? I am a bit nervous going to synthetic though because I don't understand tranny fluids that much and have heard people say that it is not recommended for the STi 6MT. What difference can the synthetic oil have on the tranny?? Synchros?? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #17 | ||
| GT R US
Car: CUTN EDG project Fav Mod: $20. mudflaps from auto zone Location: my cave Posts: 5,882
IWSTI Addict since: Dec 2003 Trader Rating: (1) | Quote:
better living through chemistry. live it. Last edited by Neanderthal Racing; 09-05-2006 at 05:03 PM. | ||
| | #18 | ||
| Silver Member
Car: Aspen 2005 STi Fav Mod: TurnInConcepts Coilovers Location: Silver Spring, MD Posts: 1,858
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Quote:
If people are running straight gear oil in the transmission, then the sloppy synchros would be expected. Edit: MT-90 is GL4 when the STI calls for GL5. Redline's 75W90 NS is a GL5 oil and seems like the right stuff, but it (like Motul and many other synths discussed here) does not have any LSD additives. The tranny has two LSD's in it. Furthermore, many report the synchros not working well with this oil depsite the oil claiming "rapid synchronization", but again, this is probably because the oil was designed as straight gear oil (though Redline lists it as working for transmission, too). I found this on the difference between GL4 and GL5 oil: Quote:
| | #19 |
| S204 Racer
Car: 04.7 AW STi Fav Mod: EQ Tuning Location: NorCal (707) Posts: 2,910
IWSTI Addict since: Apr 2004 Trader Rating: (6) | Motul Gear 300 over here. Zero issues with the fluid and no grinds at all. |
| | #20 | |
| STI Driver Car: '04 AW STi Fav Mod: Ghetto Fabulous Intake! Location: The home of the Indy 500 Posts: 259
IWSTI Addict since: Aug 2006 Trader Rating: (0) | Quote:
Even better, they seem to have the best price for the Koni Sports that I have on my wish list! | |
| | #21 | |
| | #22 |
| STI Master Car: 04 Subaru WRX STi Fav Mod: Whooshing sounds Location: Death Valley Posts: 6,104
IWSTI Addict since: Nov 2003 Trader Rating: (11) | 07/13/2008 Update! Did the major maintenance about 6 weeks ago. Went with the Valvoline 75W-90..... 4th to 5th grind and the trans is very very notchy. Motul 300 Gear on the way. Hopefully this will make the gear box happier. |
| | #23 |
| Junior STI Driver | Changed my fluid few weeks ago with Redline lightweight shockproof. Tranny shifts alot smoother and even on cold starts. With the Valvoline, it would stick in first gear when cold. |
| | #24 |
IWSTI Addict since: Nov 2003 Trader Rating: (11) | The valvoline sucks ballz, 4th to 5th grinds, it sticks so bad on startup I have to shift from 1st to 3rd............. |
| | #25 |
| Silver Member
Car: 2004 WRB STi Location: Atlanta,GA Posts: 2,066
IWSTI Addict since: Aug 2006 Trader Rating: (14) | OEM Extra-S fluid, just split it with few local STi owners and it should be good to go |
| | #26 |
| Junior STI Driver Car: 05sti,05g35,08cbr1k Fav Mod: track days Location: cullman Al Posts: 139
IWSTI Addict since: Mar 2006 Trader Rating: (0) | i know a lot of people have had trouble with amsoil but 3 years now and never a grind on any shift. even at the track.svg FTW! |
| | #27 |
IWSTI Addict since: Nov 2003 Trader Rating: (11) | It's a shame the local dealers can't tell you EXACTLY what they put in the car and that you have to go through all this bs to find out, just a shame..........crappy dealer support and technicians I can't trust. |
| | #28 |
| Amateur STI Driver Car: 04 Subaru WRX STi Fav Mod: UTEC Location: North Virginia Posts: 21
IWSTI Addict since: May 2007 Trader Rating: (0) | I used Valvoline 75W-90 for a while. I am currently using Motul 300. I cannot really tell any difference between the two. My transmission is definitely a little hard to shift, especially when cold. 3 and 4th are always fine. 1st is always the worst, then 2nd. When it gets nice and warm, shifting is fine. My '04 has 81,000 miles. No work on the tranny or clutch. I'm thinking about replacing the clutch fairly soon as preventive maintenance, though there are no symptoms. |
| | #29 | |
IWSTI Addict since: Nov 2003 Trader Rating: (11) | Quote:
I wonder if the RedLine 75W90 does contain friction modifiers. I got my Motul 300 Gear which is GL-4 and GL-5, I'm just wondering if it's ok with the front LSD. Last edited by Peleg; 07-18-2008 at 08:09 PM. | |
| | #30 |
| Professional STI Racer Car: 05' AW WRX STi Fav Mod: Passport 8500 X50 Location: Illinois Posts: 843
IWSTI Addict since: Jun 2007 Trader Rating: (2) | I LOVE motul Gear 300, my gearbox feels awesome. There are many people using Motul Gear 300 for tens of thousands and miles and have no problem with the LSD's, There's a big vendor that uses it in his personnel car forgot his name. Also motul states it has additives for differentials, I was just as worried as you, i researched different fluids for roughly 2-3months before my 30k service. This ad is not endorsed by this member. Please register or login to hide this ad. |
