Old 06-17-2006, 05:22 PM   #1
Car: 05 PSM STi
IWSTI Addict since: Oct 2004
Default OEM short shifter hardware question
On my OEM short shifter that arrived yesterday, I noticed that mine did not come with the shift linkage housing, sleeves, or bushings- just the U shaped bracket they bolt into.
This seems odd, cause every picture I see of the OEM SS has these pieces attached. Am I supposed to just take the original ones and transfer them over to the SS, or did Suabru forget to pack something in the box?
I did order the TIC bodacious bundle, so I will be using their bushings and sleeves anyway.
Oh, the shifter assembly did come with 2ea. 17mm bolts and 4ea. 14mm bolts (all grade 8) are these for the cross member and tranny mounts?
dobie0791 is offline   Reply With Quote
Old 06-21-2006, 08:08 AM   #2
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
Our bushings should work fine in that linkage core.
I don't know why they woudl include new bolts with that, but that's what they're for.
Old 06-23-2006, 07:10 PM   #3
Car: 05 PSM STi
Thanks, i was hoping to get the Kartboy/TIC bushings pressed in prior to working on the car
According to Langston Subaru, the cylinders, sleeves, and bushings no longer come with the STi SS, and must be transfered over.
