Old 03-30-2006, 10:16 AM   #16
Car: 06 STi + 96 Miata
IWSTI Addict since: Aug 2005
Originally Posted by ride_the_pony69
How many miles should I drive before I can drive the car hard after putting in the new clutch?
About 500 miles I believe.
blkwrxwag is offline   Reply With Quote
Old 03-30-2006, 12:22 PM   #17
Car: 04 Blue STi
IWSTI Addict since: Jan 2005
ok I am going to install it now, I will post how it is when I am done. I will also post how the install went too.
ride_the_pony69 is offline   Reply With Quote
Old 03-30-2006, 03:00 PM   #18
Car: The Vroom-mobile
Fav Mod: JDM Gears
IWSTI Addict since: Jun 2005
That is correct, my clutch manual said 200-300 but i waited till 400.
Old 03-30-2006, 03:06 PM   #19
A few more top tips!!...
You need 3 floor jacks... two under the tranny and one under the front of the engine. You need to keep the front of the engine high so that the tranny has room to slide out on the dowels. Without the engine jack, the engine leans forward which makes the angle impossible to pull the tranny out as it snags on the dowels.
Old 03-30-2006, 03:13 PM   #20
Fav Mod: JDM Gears
^^^ i think i overdid it, i used 6. Thats not true, you can disconnect the fork from the outside.
Old 03-30-2006, 03:15 PM   #21
I'm not taking about the fork - yes, you do disconnect that from the outside. I'm just talking about jacking the front of the engine to have the optimal angle for pulling the tranny out.
Old 03-30-2006, 03:33 PM   #22
Fav Mod: JDM Gears
Oh okay, i didnt know you can disconnect the fork the first time and i cracked the tranny loose and unbolted the clutch from there ahaha. Live and learn!
Old 03-30-2006, 06:19 PM   #23
STI Master
Car: 04 JVP STi
Fav Mod: Blitz NUR Spec R
IWSTI Addict since: Apr 2004
Ttiwwop
Old 03-31-2006, 06:21 AM   #24
Car: 04 Blue STi
well I am finishing up today and man the tranny was a pain in the a$$ to get back in. Me and my buddy spent an hour trying to get it to connect to the engine. Finally he just pulled the engine and the tranny fell right in. We thought it was getting caught up cuz of the spines wern't lining up on the shaft. Hell we punched the dowels out to make it easier to install. Oh and we use one jack the whole time too.
Old 03-31-2006, 04:28 PM   #25
Car: 04 Blue STi
Well all done! Car runs like a champ too. Just had a little trouble getting the throw-out bearing to seat and the slave cylinder for the clutch was a pain to get bleed also. Other then that not too bad but now I can probably do it faster if I had to do it again.
Old 04-02-2006, 11:23 PM   #26
Car: 04 Blue STi
Here is a pic of what the clutch looks like (click on the link below)
http://www.putfile.com/pic.php?pic=4...0013.jpg&s=x11
Old 04-03-2006, 06:52 AM   #27
Moderator & ECU Tech
Fav Mod: mo boostaz
IWSTI Addict since: Jun 2004
I would like to know more about the SPEC with regard to daily driving. How is the pedal effort compared to stock? How is the 'grabbing' compared to stock? Is it jerky? Is it a lot more difficult to engage smoothly?
t
Old 04-03-2006, 08:42 AM   #28
STI Master
Car: 04 JVP STi
That's a nice looking clutch. Impressions compared to stock??
Old 04-03-2006, 05:13 PM   #29
Car: 04 Blue STi
smooth engagement, a little stiffer pedal feel, and a little getting used too starting off in 1st gear. I am still breaking it in so I don't know how it really is yet. It can be jerky but you just gotta learn how to work the clutch.
Old 04-03-2006, 07:33 PM   #30
Fav Mod: JDM Gears
hows that compare to the design to this?
http://i2.tinypic.com/sya6c5.jpg
