Old 03-10-2006, 08:22 AM   #46
Fav Mod: FYI, I'm a dude
IWSTI Addict since: Mar 2005
Originally Posted by klaymon
Right. So I think what he's driving at is, using a 0w-40 oil that covers such a broad range of temperatures is not really necessary since during 3000 miles you most likely will not see a swing of -10 degrees up to 90 degrees. I'm not arguing a point, I'm just rewording what was already said.
i agree. i basically just look at the 0w-40 as an all around alternative to 5w-30 for those that want an oil with a little bit broader range. most of us generally keep a bunch of extra oil on hand in the garage. you can use it year round and not have to keep a stock of several different oil weights. to some people, this is appealing. they can stick with this weight and forget it like the 5w-30.
lokutus1 is online now   Reply With Quote
Old 03-10-2006, 10:36 AM   #47
IWSTI Addict since: Jul 2004
Which is exactly what I do (5w-30). I was just rephrasing what was said. I'm definitely not getting into this discussion on the technical merits. I use what I use and I like it. Carry on.
klaymon is offline   Reply With Quote
Old 03-10-2006, 10:51 AM   #48
cool
Old 03-10-2006, 11:12 AM   #49
Car: 2006 STI
Fav Mod: Recaros
IWSTI Addict since: Sep 2005
One downside of 0-40, however, is that there is a lot of modifier going into the oil to give it that range, which means less base.
Old 03-10-2006, 12:53 PM   #50
asf
IWSTI Addict since: Feb 2006
That and heavier weight = lower fuel efficiency.
AS long as you are aware of the tradeoffs
Anyways, I think I've added (or detracted) all that I can to this conversation. Carry on
asf is offline   Reply With Quote
Old 03-10-2006, 01:00 PM   #51
i'm with asf. good luck with your oil choices fellas
Old 03-10-2006, 05:19 PM   #52
Car: 06 IX MR
IWSTI Addict since: Mar 2002
Trader Rating: (12)
Send a message via MSN to 91TB78 Send a message via Yahoo to 91TB78
Of course, during the hot summer months having a higher viscosity is generally a good thing since our motors run pretty hot. I'm using Amsoil 5W-40 Euro blend for winter and then come summer I'll go back to either 10W-30 or 10W40 Amsoil.
Although I don't notice any measureable loss and I check my oil all the time, I did notice a light amount of oil in my intercooler inlet. Proof enough that a catch can should help even stock cars.
91TB78 is offline   Reply With Quote
Old 03-10-2006, 05:36 PM   #53
Car: Dolphin Grey B6 S4
Fav Mod: i miss my sti
IWSTI Addict since: Oct 2005
this might be a bit OT (and if so, ill start a new thread), but why is that some engines burn oil while others dont?? my uncle and i both have relatively new STi's running dino oil (his an 05, mine an 06). we both broke it in according to the "drive like you stole it method" and while my engine doesn't burn oil and at, his burns quite a bit. what could be so different between the engines?? i didnt seem to affect performance as our cars are always neck and neck; i can usually outdrive him on backroads, but i can do equally well in both cars.
Jas0nn is offline   Reply With Quote
Old 03-10-2006, 05:46 PM   #54
Car: 06 IX MR
Trader Rating: (12)
Every car has too many variables to really isolate what is causing the burn. What type of oil and weight do you both run?
Old 08-17-2006, 01:12 AM   #55
Car: 04 STi WRB
Fav Mod: red interior lights
IWSTI Addict since: Aug 2006
Originally Posted by SUBIRU
i use amsoil, 5w-30. don't really know how long i'm suppose to go before oil changes so i just do it at the norm 3k intervals..
well i guess 3k been normal is an arguable point too...definately not normal is you go by the manual, which recommends it every 7,500...of course it does mention that if you are in severe weather and driving conditions you should do it more often - so maybe every 5,000 but every 3,000 seems like unnecessary waste of $$$....after all do you really plan on driving your STi forever or would you rather get something new in say 5 years that has 450hp???
0bluesti4 is offline   Reply With Quote
Old 08-19-2006, 03:14 PM   #56
Car: 04 PSM STi
Fav Mod: Yakima Roof Rack
IWSTI Addict since: May 2005
Send a message via AIM to booSTi561
I just had my 30k mile service and noticed they changed the oil. Ugh. They use this crapy 10W30 Motorcraft and I burn that up like Ricky Bobby on a race track. I was using Mobil 1 Synthetic (in which I didn't burn an ounce of), but now Im going to switch to Royal Purple since I just found an awesome deal on the internet (comes out to $5.50 per a quart).
booSTi561 is offline   Reply With Quote
Old 08-20-2006, 07:59 AM   #57
Car: 2005 Subaru STi
Fav Mod: Cobb Swaybars and Kartboy Endlinks
I've been told by Subaru mechanics that synth oil is fine, but once you start using it you should stay with it.
krees23 is offline   Reply With Quote
