Old 02-12-2006, 01:20 PM   #1
Car: 05 aspen white sti!!
IWSTI Addict since: Jan 2006
Send a message via AIM to kidjnco23
Default ABS light
i was tryin to get out of my driveway earlier along with the 3ft of snow and my abs ligh came on will it go off eventually??
kidjnco23 is offline   Reply With Quote
Old 02-12-2006, 05:39 PM   #2
Muller Chevrolet
Fav Mod: a new 09 STi
IWSTI Addict since: Oct 2004
dude mine came on today too while doing donuts and then it just went off...idk what it means.
VSGTS14 is online now   Reply With Quote
Old 02-12-2006, 06:33 PM   #3
Car: TIC Spec OBP STi
Fav Mod: Cobb AP V2
IWSTI Addict since: Apr 2005
mine came on after i went over some bumpy rodes then a few minutes later just turned off. if its stays on any longer take it to the dealer, just to be safe.
pharo is offline   Reply With Quote
Old 02-13-2006, 04:05 PM   #4
aight thanx!!!
Old 02-13-2006, 05:40 PM   #5
Car: '08 BMW 135i
IWSTI Addict since: May 2005
Trader Rating: (13)
I have the same issue when I start the car once in a while. I just turn the car off and then re-start it and it goes away.
I tried re-flashing back to stock and it still does it once in a while. I don't know what it means.
MadMan77 is offline   Reply With Quote
Old 02-14-2006, 10:18 AM   #6
Car: 06 Subaru WRX STI
Fav Mod: None Yet
Mine came on when I was trying to get out of the snow also.. I'm bringing my car to the dealership next monday and they said that they will take a look at it.. I'll let you guys know how it goes.. Mine has less than 2K miles on them 2. Damn ABS!!!
smey06STI is offline   Reply With Quote
Old 02-14-2006, 10:23 AM   #7
Car: 05 CGM STi
IWSTI Addict since: Jun 2005
You could have knocked an ABS wheel speed sensor off if you were driving through very deep snow. I would look under neath and see if anything's hanging.
solbergfan is offline   Reply With Quote
Old 02-14-2006, 11:46 AM   #8
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (53)
I keep meaning to post in here, but keep getting distracted. You have one of two problems.
1) if you have high milage on your car then your pads are worn, and you need to add a bit of brake fluid to the MC.
2) if you have the light due to donuts or snow driving you have done one of two things. a) vehicle speed sensor and ABS wigged out and you need to reset the ECU b) you have broken an ABS sensor lead as suggested above.
Edit: as pointed out below I am an idiot. For case number 1 it would be your brake light that would flash. BTW, there is a computer unit at the dealer that can pull the ABS codes. i thought that there was a way to do it by jumping some diag. plugs, but given how I'm doing today I would check for confirmation on that.
Turninconcepts.com is online now   Reply With Quote
Old 02-14-2006, 12:36 PM   #9
Car: 05 CGM STi
^^^^Does a low brake fluid level trigger the ABS light in the STi? In most vehicles it will trigger the 'BRAKE' warning light (e-brake indicator). Also, be careful adding brake fluid if the level is low due to brake pad wear-when the new pads are installed and the pistons in the caliper are compressed, the fluid will spill out over the top of the master cyl.
Old 02-14-2006, 12:46 PM   #10
Trader Rating: (53)
DOH!!! You are correct. I was not thinking. I'll edit my post.
Old 02-15-2006, 09:55 AM   #11
Fav Mod: None Yet
Good News, I finally took my car out (I still have those damn summer tires) to drive today and the ABS light disappear. Now I have to call the dealership and tell them it went away. I think that it was the snow and slipping of the wheels that cause them to come on. I'm not complaining anymore it went away.
