Old 01-23-2006, 05:36 PM   #1
Car: 08 Silverado 2500HD
IWSTI Addict since: Dec 2005
Default COBB Short Shifter Question:
I recently put in a cobb short shifter and the ring just below the reverse lifter thing hits the silver ring that has STI inprinted at the top. The ring is held down by screws if you dont know what im trying to say... Anyways anyone else have this problem? Obviously it hits when going into 2nd 4th and 6th. If you do have this problem as well, what did you do to fix it?? thanks guys.
1FSTSTI is offline   Reply With Quote
Old 01-23-2006, 05:43 PM   #2
Community Consultant
Car: 2005 OBP STi
Fav Mod: Learning
IWSTI Addict since: Aug 2005
Send a message via AIM to CicioSTi
are you saying that your shifter is hitting on the plastic STi Bessel that surrounds the shifter?
If so you have your throw adjusted way to long, the bottom adjustment needs to be lifted up, this will shorten the throw, and center your shifter.
If thats not what your talking about, then correct me,and I will try to help.
CicioSTi is offline   Reply With Quote
Old 01-23-2006, 06:25 PM   #3
Car: 04 PSM STi
Fav Mod: Yakima Roof Rack
IWSTI Addict since: May 2005
Send a message via AIM to booSTi561
i think u'll get a better response if this was moved to the driveterrain
booSTi561 is offline   Reply With Quote
Old 01-23-2006, 06:37 PM   #4
Car: 2005 STI
IWSTI Addict since: Jun 2005
I think you mean the shift boot holder (-takes to 2 screws) is hitting the silver boot trim? You need to lift the top half higher if you have a long throw(bottom half short).
If you have a short throw(bottom half long) then you would lower the top have. This would center your rod and give you clearance.
Hope this helps...
STI5150 is offline   Reply With Quote
Old 01-23-2006, 08:00 PM   #5
Sweet. I will do that. CicioSTI yes that is what i was talkin about. I will do that adjustment. Thanks a bunch.
Old 01-23-2006, 08:03 PM   #6
Car: 2005 OBP STi
Fav Mod: Learning
I have mine adjusted almost all the way up on the bottom adjustment "throw" and all the way down on the top adjustment. just play with it, and you will find what you like.
I actually drove around with the shifter boot off, and an allen key shifting/stoping..playing with it, and trying again.
let us know if you need any more help.
Old 01-24-2006, 11:22 AM   #7
thanks
Old 09-24-2008, 08:58 PM   #8
Car: silver 05 wrx sti
Fav Mod: My Tuner!!!!
IWSTI Addict since: Mar 2008
Default Re: COBB Short Shifter Question:
yeah i have that same problem, but with mine it doesn't feel like it goes into 2,4,6 and revers but with i let go of the clutch it goes. i just want to now that it wont hurt my tranny?
Moisti is offline   Reply With Quote
