Old 12-10-2005, 01:11 PM   #1
Send a message via AIM to jermdeez
Default Adjusting stock clutch
Mechanic for gruppes trannys told me there was a way to do a slight adjustment of sti clutch, maybe just changes height of friction point im not sure,but does anyone know how to do it?? he said it's not difficult??? I can't find anything about this on the net, he madei t seems like it was sortuv a secret.
jermdeez is offline   Reply With Quote
Old 12-10-2005, 01:20 PM   #2
Car: 05STi
Fav Mod: None
all cars have this adjust screw on the clutch pedal, it controls how much "free play" a clutch can have. i don't know much on the STi, but i did a few times before with my RX-7, i suggest you find the online service manual and look for how to adjust free play on the clutch
-mike
traction_issuez is offline   Reply With Quote
Old 12-10-2005, 01:22 PM   #3
Car: 04 Silver/Silver STi
Send a message via ICQ to kyongyun Send a message via AIM to kyongyun
He's probably talkin about adjusting the clutch pedal stroke. http://www.auto-epc.ru/2004%20STI/04...ch%20Pedal.pdf
But anyway its a link to the manual and how to adjust the clutch peda. You can't really adjust the clutch engagement point itself because its a hydraulic clutch.
kyongyun is offline   Reply With Quote
Old 12-10-2005, 01:27 PM   #4
link isn 't working, what does adjusting the clutch pedal stroke do exactly?
Old 12-10-2005, 02:05 PM   #5
my bad, the site isn't working anymore. I have the copy of the file.
http://home.sc.rr.com/kyong/10.%20Clutch%20Pedal.pdf
the clutch pedal stroke is the length of the clutch pedal movement from being depressed to being released.
Old 12-10-2005, 02:10 PM   #6
Car: 05STi
Fav Mod: None
it moves the catch point basically.
because adding more tension to the hydraulic line it acts like if your pressing the clutch even though you are not, so it basically moves the "power band" as some would say in engine terms.
Old 12-10-2005, 03:42 PM   #7
would the dealer do this?? it seems complicated i don't want to mess it up. my pedal is all the way at the top and it makes quick shifting irritating
Old 12-10-2005, 05:18 PM   #8
Car: 06 cgm sti w/ppg dog
Fav Mod: RIP 04 psm sti
Send a message via AIM to nhsilversti Send a message via Yahoo to nhsilversti
it is very easy to do. all you need is a 12mm wrench(maybe 14mm) to loosen the not on the back side of the pushrod on the clutch pedal. DO NOT ADJUST MORE THAN 1/2 TURN AT ONE TIME. try it and see if you need to go more, a little adjustment makes a big difference.
ted
nhsilversti is offline   Reply With Quote
Old 12-10-2005, 11:45 PM   #9
which way should i turn? loosen?
Old 12-11-2005, 05:34 PM   #10
sorry but, if you NEED to ask, you should not touch it. have the dealer or mechanic friend do it for ya.
ted
Old 12-11-2005, 05:41 PM   #11
Car: 01 Subaru WRX STi Spec C
Righty tighty, lefty loosy.
Or Clockwise and Counterclockwise.
Matt30 is offline   Reply With Quote
Old 12-15-2005, 09:20 AM   #12
Car: 03 Impreza WRX STi
Fav Mod: fog lights
and why do you want to adjust it? there is nothing better than the stock adjustment.
dxb_evo is offline   Reply With Quote
Old 12-15-2005, 02:42 PM   #13
Fav Mod: camber plates
If there's room for improvement, why not. Stock isn't always better. Thats the reason we're modd'n the hell outa this car. lol
rockD is offline   Reply With Quote
Old 12-15-2005, 06:08 PM   #14
i agree, i hate my clutch. it is a pain. i will look into this.
AdamBlitzer is offline   Reply With Quote
Old 12-17-2005, 02:29 AM   #15
This adjustment is very easy to do. I did this on my 350Z and now I just did it in the STI. The result?., the engagement point is much sooner from the floor to "grab".. faster response. The feel?.., a lot less effort, more like not fighting the clutch anymore (for lack of better word), smoother shifting as well.
First thing is get familiar with your clutch mechanism. This is the clutch of a 350Z. It's nicely labelled and its basically the same as any other clutch. http://photobucket.com/albums/y46/ro...t=Clutch1a.jpg
