Old 04-07-2006, 10:35 PM   #31
I Has a Turbo Timer
Fav Mod: Every single one!
Trader Rating: (24)
Was just on the website...which one is the BEST for the gearbox and rear diff? So many to choose from....
Old 04-08-2006, 05:06 AM   #32
Car: 08 Aspen STi
Send a message via AIM to Arcticsun
stick with valvoline dino 75w-90 to avoid problems with synthetic, and motul 90pa for the rear diff
Arcticsun is offline   Reply With Quote
Old 04-08-2006, 07:10 AM   #33
Car: 06 IX MR
Trader Rating: (12)
Send a message via MSN to 91TB78 Send a message via Yahoo to 91TB78
I'm doing this in about 10 mins. I bought the LSD fluid from subaruparts.com for the rear diff and then bought Valvoline 75W-90 for the front/tranny.
Do you think it's a must to get a fluid pump to remove the remaining fluid?
91TB78 is offline   Reply With Quote
Old 04-08-2006, 07:20 AM   #34
Rev
STI Guru
Car: 06 V70R
Send a message via AIM to Rev
You'll need the pump to put the fluid in, at least it seemed hard to me to find a proper angle to tip in the bottle into the hole... no space in there...
Old 04-08-2006, 07:41 AM   #35
Car: 06 IX MR
Trader Rating: (12)
so the pump is used to remove the remaining fluid left in the diff and tranny AND to fill it back up?
Old 04-08-2006, 07:46 AM   #36
Rev
STI Guru
Car: 06 V70R
For the tranny I just removed both drain bolts, and jacked the car from the rear to push the fluid forward, I ended up filling 4.3 quarts, so that was enough. No pump needed for draining at least.
The pump is certainly needed for filling the rear diff, though.
A long necked funnel helps to fill the tranny, unless you're taking the IC out.
This time I'm taking the pan off and resealing (when I hit 40k miles, though)
Old 04-10-2006, 12:59 PM   #37
Car: 2006 Subaru Wrx STi
Fav Mod: HKS CERAMIC COATED HEADERS
i used redline 75w90 gnl 1qt with friction modifiers and the trans used 4.50 qt of 75w90 without friction modiers.cleaner shifts.....i would change it every 12 k i changed mine at 18k and it was dark.......
StiManny is offline   Reply With Quote
Old 04-10-2006, 01:55 PM   #38
Car: 06 IX MR
Trader Rating: (12)
I did the change for the tranny and rear diff this past Sat. The tranny was a breeze, but filling the diff was a messy pain. The pump I bought wasn't all that great. For those that have had good results, what type of pump are you using?
Old 04-12-2006, 06:29 PM   #39
Car: 2005 CGM STI
Fav Mod: Cobb TBE
Send a message via AIM to BHazel Send a message via Yahoo to BHazel
Originally Posted by EricK
You must use one of the three fluids listed above for the rear LSD diff.You need to use Subaru 90 wt. LSD oil or Motul 90PA LSD oil or Silkolene BOA90 LS.If you dont your rear diff. will lock up at strange times or be noisy.
I thought I had heard people using the Amsoil in the diffs with no issues. Why would this not work?
BHazel is offline   Reply With Quote
Old 04-12-2006, 06:31 PM   #40
Car: 2005 CGM STI
Fav Mod: Cobb TBE
What issues with synthetic?
Old 04-13-2006, 07:47 AM   #41
Car: 05 CGM STi
Amsoil does not make a mechanical LSD specific oil.
solbergfan is offline   Reply With Quote
Old 04-13-2006, 03:07 PM   #42
Car: 2005 CGM STI
Fav Mod: Cobb TBE
This is the Amsoil Severe Gear oil.
https://www.amsoil.com/storefront/svg.aspx
It states limited slip compatable.
Old 04-14-2006, 03:35 AM   #43
Car: 02 RSX Type S
Fav Mod: 4300 H.I.D. Kit
do all STI's come with the magnetic drain plug or was it an option?
Big Cam is offline   Reply With Quote
Old 04-14-2006, 04:07 AM   #44
Car: 05 CGM STi
It is compatible with hypoid or helical gear type LSD's like the one found in the standard WRX. The STi has a mechanical (clutch type) LSD therefore it requires the mechanical LSD oil. Amsoil does not make anything compatible with a mechanical LSD, neither does Redline or Royal Purple.
Old 04-14-2006, 03:15 PM   #45
Car: 2005 CGM STI
Fav Mod: Cobb TBE
Here is what I sent to Amsoil Tech Support:
I have heard some conflict about the application of the SVG gear oil. I have a 2005 Subaru Impreza WRX STI and was wondering if the SVG oil could be used in the limited slip rear differential. I plan on putting it in the front differential and the transmission. Also, is the SVG gear oil compatable with brass syncros? Thank you,
From Amsoil:
"Thank you for contacting AMSOIL with your concerns.
In response to your inquiry, the SVG is recommended for the transmission, front and rear differential. It is safe for the synchros.
Thank you again for the opportunity to respond to your concerns. As always, please feel free to contact us again if we can be of further assistance.
Darryn Wallace
Technical Service Department
AMSOIL, Inc."
I will email them again with specifics on the rear diff. I just got a case of the SVG oil and intend on finding out if I can use it.
