Old 03-06-2006, 03:58 PM   #81
Car: 05 STi, Black
Fav Mod: Graduating from college, and falling in love with turbines...big and small.
IWSTI Addict since: Nov 2005
Just did my fluid change today, used the yummy stuff (per Bruce's comment - Motul Gear 300); got it for $12/liter ($15 shipped) here: http://www.ngpracing.com/Merchant2/m...y_Code=gearoil
First off, I knew I had my share of missed shifts, so I reasoned I'd inspect the screen and magnet. Well, to my surprise, my magnet was fully coated in metal shavings/material...ouch!!! FWIW - I've driven approx. 31k miles over the past 15 months, good miles too. The screen is enclosed within the fluid pickup assembly, and the magnet is fixed onto a boss/raised section on the pickup. Could see one tiny FOD entrapped in the screen - but I wasn't about to stick anything in there; for one thing the orifice where the fluid is sucked up through had some sharp edges. When the fluid came out it was deep honey colored; can't say it smelled bad - it smelled just as bad as the new stuff.
Followed advise per this post:
What you need for transmission fluid change.
After I closed everything up, I went out for a slow test drive. First thing I noticed was the shifts were a bit more noticeable, i.e. "clicky" (that's the best way to describe it). I drove around for a while listening for the usual 2nd & 3rd gear grind - it was as good as gone. Only while pulling up slowly into my driveway in first did I hear the only bit of grind, and it was much less than ever before.
That's the best I can do to summarize at this point. I can give a road test update later - if you guys are interested. Sorry I don't have any pix, but I have no camera right now...batteries both went flat.
blackie1969 is offline   Reply With Quote
Old 06-03-2006, 09:01 PM   #82
Car: white 05
Fav Mod: the driver
IWSTI Addict since: Apr 2005
Originally Posted by asf
So let's get a PN for this mystery oil already! I live nowhere near them and want to make sure my stealership has this pil (assuming it is not for private sale, + 1 jug will probably last me longer than the car...)
I found this on one of the many other threads that come up when you look for tranny fluid with the search tool. p/n: K0323AA093 . you can get it from subaruparts.com and subarugenuineparts.com . It only comes in like a 5 gal buckett for $130 though.
samuraiTy is offline   Reply With Quote
Old 06-03-2006, 10:41 PM   #83
Feedback Score: 21 reviews
Car: 05 Subaru WRX STi
Fav Mod: RCE T2 Coilovers
IWSTI Addict since: Jun 2005
Send a message via AIM to AndrewSS
I have heard that its a good idea just to get 75w90 valvoline dino gear oil - its what the dealers use I have heard.
AndrewSS is offline   Reply With Quote
Old 06-03-2006, 10:56 PM   #84
Car: 94 Miata R 04 STi
Fav Mod: Gotta be more and more seat time
IWSTI Addict since: Feb 2006
Send a message via AIM to Homi Mike Send a message via MSN to Homi Mike
I went with the Vavoline dino oil. Can't go wrong with this and I am very happy with it.
Homi Mike is offline   Reply With Quote
Old 06-16-2006, 11:07 AM   #85
IWSTI Addict since: May 2006
Where is the tranny oil container?
InFlamesFan is offline   Reply With Quote
Old 10-20-2006, 07:53 PM   #86
Feedback Score: 1 reviews
Car: 04 Blue STi
IWSTI Addict since: Jan 2005
I am using royal purple 75w90 for my tranny. Can you use the same for the rear diff?
ride_the_pony69 is offline   Reply With Quote
Old 01-10-2009, 06:00 PM   #87
Car: wr blue 06 wrx tr
Fav Mod: k&n typhoon
IWSTI Addict since: Dec 2008
Default Re: Tranny Oil advise on STi 6MT
Subaru gear oil 5 gal. Part number k0323aa0093 subaru 90ls lsd oil 1 liter part number k0305y0900 only use these!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!
boo-key bear is offline   Reply With Quote
Old 01-12-2009, 09:16 AM   #88
Car: 06 Subaru WRX STi
Fav Mod: leaving it stock
IWSTI Addict since: Apr 2007
yes...
went down to local subaru dealership to pick up some trans and rearend oil for my 30K...said they didnt have any and to pick up some redline 75w90 w/ additive... 6 quarts should be enough...rearend took a little more than 1qt...and a little more than 4 for the trans...
houdni is offline   Reply With Quote
Old 01-29-2009, 11:56 AM   #89
Car: 2004 WRB STI
Fav Mod: TURBO XS TBE (RFL, TI-TIP)
IWSTI Addict since: Sep 2008
Send a message via AIM to sjrgreenkight13
so when buying transmission and rear diff fluids:
5 quarts for the transmission
2 quarts for the rear diff
this is going to be enough?
sjrgreenkight13 is offline   Reply With Quote
Old 01-29-2009, 12:04 PM   #90
STI Master
Feedback Score: 15 reviews
Car: Halp I has no boost!
IWSTI Addict since: Nov 2003
Originally Posted by pantag View Post
The stock tranny fluid is Valvoline (non synthetic) 75W-90. Some people go with the dino oil some with Motul. I've heard good things about Motul.
I don't know if that's accurate, the stock fluid to my believe is Subaru trans fluid is the Subaru Extra S.
In any case, I'd go with that or the Motul 300 Gear.
I would not go with the Valvoline.
Privacy Policy
