Old 10-11-2005, 06:09 PM   #1
Car: PSM '04 STi
Fav Mod: 6pt harness
IWSTI Addict since: Apr 2004
Default Conversion for drift?
Any info on driveline conversion for drifting? Anyone drift?
nero9 is offline   Reply With Quote
Old 10-11-2005, 06:20 PM   #2
Car: '04 WRB
Fav Mod: A working ECU...
IWSTI Addict since: May 2003
You mean the S2000 conversion? I think it'd work well...
Old 10-16-2005, 10:48 PM   #3
Car: PSM '04 STi
Haven't heard of the s2000 conversion. I assume it's the tranny?
Old 10-16-2005, 10:49 PM   #4
www.Subie.tv is niiice
IWSTI Addict since: Aug 2003
Do a search lest you get flamed...
Old 10-16-2005, 11:54 PM   #5
Car: 05' STi CGM/Silver
Fav Mod: Recaro Sports
IWSTI Addict since: Oct 2004
Yes, its the transmision.... oh and everything else attached to it. (yeah.... the whole thing...)
STi05' is offline   Reply With Quote
Old 10-17-2005, 11:08 AM   #6
Car: 05 CGM STi
IWSTI Addict since: Jun 2005
I'd try the Silvia conversion-parts are cheaper.
solbergfan is offline   Reply With Quote
Old 10-17-2005, 02:51 PM   #7
Theres a great video on here of a guy in a RWD converted wagon crashing into a tree.
Old 10-18-2005, 08:01 AM   #8
please dont turn you sti into a drift car.......please
White05sti is offline   Reply With Quote
Old 10-21-2005, 11:20 AM   #9
Car: WRB STi - WRR 92X
IWSTI Addict since: Sep 2003
It's very easy.
Since drifting is not about speed it's 4 wheel drift style
Go get yourself 4 STi 17" donuts then you can drift the 4 wheel all day long - J/K....
And also prevent you from breaking down the tranny..
They are cheap too :P
salaki is offline   Reply With Quote
Old 10-22-2005, 11:43 PM   #10
Car: PSM '04 STi
No, I don't intend to make it into a drift car. I've just seen a couple of vids over the past few days, so wondered what was involved. Anyone done it?
Old 10-23-2005, 09:18 AM   #11
IWSTI Addict since: Jul 2004
get some snow tires (non studded) that are rated CRAP for the dry season...have fun!
i'd know, ive tried
-spyer
jlcool007 is offline   Reply With Quote
Old 10-23-2005, 06:39 PM   #12
STI Master
Car: 04 JVP STi
Fav Mod: Blitz NUR Spec R
I'll sell you the tires off my car right now.......there so balled you can't help but slide around.
Old 11-02-2005, 12:01 PM   #13
Car: 07FXT. Fast
The only thing you need to do to an STI to drift it is
Learn how to drive it. STIs will do it bone stock with the right driver.
If I was going to mod it specifically for drifting...
Coilovers with at least 10K rates, if not 12k
27mm front sway
heaviest rear sway
Replace every bushing in the back end of the car with as hard of material as possible
Cusco front diff
Cusco (or other brand) rear diff. As agressive locking as I can get
Set DCCD to full rear. leave it there.
Port/polish stock exh manifolds then wrap them
Wrap up pipe, grind transition into it from manifold as smooth as possible
Td06-25G 8cm exh housing Wrap exh housing
Em/exh(catless) Set redline to 8k
Alch injection, running 100% methanol
FMIC, ceramic coat AND wrap pipes
Roll CAGE << MOre stiffness than other braces
Cusco rear under brace
Cusco H brace up front
Cusco strut bar rear+V brace
Weld extension to E brake handle
Disable the button that locks the e brake up
Drivers race seat (HIGH side bolsters, REALLY high)
Cams. Something with a powerband up to 8K
Valve springs
Considering you can drift a stock STI, that setup should do pretty well
Davenow is offline   Reply With Quote
Old 11-02-2005, 06:49 PM   #14
Car: 06 B-SPEC Legacy wit
Fav Mod: AP Pedals and Motons
IWSTI Addict since: Oct 2005
Send a message via AIM to GTWORX.com
27mm front sway
heaviest rear sway
Cusco front diff
Valve springs
that will do it
duct tape does wonders for "disabling" the ebrake handle button...
GTWORX.com is offline   Reply With Quote
