Old 02-01-2006, 06:06 PM   #76
Car: 06 Subaru WRX STi: A
Fav Mod: exhaust
IWSTI Addict since: Oct 2005
thanks for the reply. That is a very important point.
I think maybe my post was a little too harsh. Probably over dramatized on my part. Either slow shifting or fast, i find the gates between 1-3-5 to be too wide.
When i come up from second, i hit/rub the gate between first and third.
In my old 5spd wrx I very rarely missed the "third" shift, and it was only when i was rushing it. WIth this new 6spd I was hoping a bushing set would help my situation. But i'm unsure if the bushing sets work with an 06.
Any other tips for shifting Bruce?
battlecat is offline   Reply With Quote
Old 02-01-2006, 06:45 PM   #77
GT R US
IWSTI Addict since: Dec 2003
1 and 3 is very narrow, battle. that's why you don't want to "find" it. 5th is a longer throw and requires more effort. if you fell like the 1/3 is as wide as the 3/5, youre working way too hard on the 1/3.
we ought to get one of the guys who actually know what theyre talking about to help.
Old 02-02-2006, 06:30 AM   #78
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (54)
You're working to hard at trying to nail 3rd, and in doing so you're pushing the stick over just a little too hard which causes the hangup on the gate. Most of the time this is caused by excitement, but that ususally the worst time for it to happen. The stick goes over a little too easily because of the side to side slop in the shifter. For what it's worth what you are describing is EXACTLY the problem we were having, and what led to the development of our shift linkage bushings.
To answer your question - the 04-05 linkage bushings will not fit the 06. We are working on the 06 fix.
Old 02-28-2006, 09:57 PM   #79
asf
IWSTI Addict since: Feb 2006
Originally Posted by Turninconcepts.com
You know what - I went looking for that long thread that discusses the vibration, and things to check, and I can't seem to find it easily. Therefore, I'll just post up the list of things to check here, and make life easier for everyone involved.
1) Check the torque of the bolt at the fulcrum. Spec is 8.3 lbs. Any more and if feels like crud, and any less and it will make noise.
2) Check the torque on the linkage bolts. You want 11 lbs.
3) Definately check to make sure the lockout cable is zip tied in two places. First on the lever near where the end of the cable goes into the lever, and second, that the cable is zipped to the stay under the car so the cable doesn't rub on the driveshaft. This is probably the number one reason for noise that I get emails about.
4) Check to make sure the control arm off the shifter is not rubbing on the metal surround for the rubber boot. turning the plate 180* or grinding a little will fix this. There are details on scoobymods in the 6mt lever instructions.
5) Make sure you have grease inside the lever for the lug at the end of the lockout cable. Unscrew the shift knob, take a q-tip with some grease on the end, and smear it around down in there. Give it a couple of days to spread inside the shaft.
6) Make sure the cup for the ball at the end of the lever is fully seated, and that the snapring is fully seated in the groove.
7) Make sure it's not the lockout pull rattling. When you hear the noise try lifting on the lockout pull very slightly. If that fixes it, then you need to add a little bit of pretension to the cable. The adjuster is on the washer for the front stay, and adjusts like a bicycle brake cable.
8) Make sure you reused the foam donut thingie (sorry, that's the best way I can describe it) from the stock shifter. It sits on that flat "washer" on the lever below the spring for the lockout pull.
I think that might be everything to check, but if I remember more I'll put it on here.
-Clint
[moderator edit: added Clint's "one more" to this post as #8 above]
Great master list!
asf is offline   Reply With Quote
Old 03-12-2006, 02:58 PM   #80
Car: BMW M5 993 Turbo
IWSTI Addict since: Sep 2005
Originally Posted by UrbanKnight
Did you actually tighten the linkage I posted above? I am confident that is your issue.
UK
Done and done. This was it. Sorry I didn't reply sooner. Thanks for the advice! The rattle is HISTORY!
aspensti05 is offline   Reply With Quote
Old 05-01-2006, 09:06 PM   #81
Car: 2005 Subaru WRX STi
IWSTI Addict since: Feb 2005
Send a message via AIM to Mochenmat
...ahem make sure you explane how you get these bushings out....so they don't end up like me...
Mochenmat is offline   Reply With Quote
Old 05-03-2006, 08:55 AM   #82
Trader Rating: (54)
there are a couple of ways you can get them out - push from the inside with a screwdriver or pull them out by the flange. The technique I have been using lately is to use a knife to get under the edge of the flange and then pry around the bushing, pulling it out little by little. Just be sure not to cut the bushing when you do this.
What happened to you?
