| | #46 | |
| Professional STI Racer Car: 04 Subaru WRX STi Fav Mod: leather Location: Newtown to Philly every day Posts: 603
IWSTI Addict since: Jun 2005 Trader Rating: (0) | Quote:
Are the bushings connected to the amp? Please if you could give me directions for the spring. This way if she is still rattling I can try the spring. I love my TIC kit, any rattle is worth it and earned. Thanks again. This ad is not endorsed by this member. Please register or login to hide this ad. | |
| | #48 |
| Spec C Club Car: BMW M5 993 Turbo Location: Southwestern, CT Posts: 1,293
IWSTI Addict since: Sep 2005 Trader Rating: (5) | Yup...it's the oring alright: ![]() ![]() Anyone know what that twisted wire is near my pliers in the 2nd pic? That doesn't look stock/standard. So...where do I go to buy a new oring and what are the specs? I believe lowes sells them, if someone can tell me the diameter and thickness. Also what kind of grease is that? It looks like I need more. Note to future TiC ultimate shifter buyers. This shift kit is AWESOME, just install it yourself because shops don't care and screw it up! They just want your money. For reference this was installed by Pruven Performance. You've been warned. See my journal for the other crap they did when I used them. Last edited by aspensti05; 12-22-2005 at 12:31 PM. |
| | #49 |
| Authorized Vendor | That wire is there to hold the dust boot to the cup. it's perfectly normal. Crap on the o-ring. pull the basket out and check to make sure there are two. One up toward the top in a grove and the other goes in a declevity at the bottom of the basket. from my doing this over and over I believe that they two are the same size so take the bottom one (if you still have it) and go to home depot or lowes and see if you can find a replacement. if you cannot find a replacement please let me know ASAP (call me 513-235-5150) and I will get to work on getting one sourced from Subaru. edit: Oh, and that grease is just any old grease. wheel bearing grease is what I use, but litium grease works fine too. |
| | #50 | |
IWSTI Addict since: Sep 2005 Trader Rating: (5) | Quote:
They had none the right size or thickness available indvidually or even in a pack.That said it's all back together. I picked up some white lithium grease too I hope that's ok. I was hoping it would feel different running through the gears in the garage, but it didn't. I'm away visiting my family for Christmas the next two days, so I probably won't get a chance to drive it till Monday or Tuesday. I'll report back then. Clint, thanks again for your awesome willingness help and response time. | |
| | #52 | |
| Senior STI Driver Car: 05 Sti Fav Mod: One touch 4 door unlock Location: Daytona Beach, FL Posts: 378
IWSTI Addict since: Jan 2005 Trader Rating: (0) | Quote:
I had this same rattle after my install. Exactly the same symptoms after about a week of driving. I apologize that I don't know the name of this part, but it is the bolt on the control arm that runs vertically, with the top bolt that has no head, just 2 flat notches. If you tighten that bolt, all will go away. trust me, I tried everything prior to finding that..(dynamat the console, shifter ties, reverse lockout cable, every bolt BUT that one, etc) I had to use mini vise grips to lock on to the lack of bolt head, and then a stubby 12mm wrench on the nut. Couldn't be happier now, not a hit of noise in any gear! UK | |
| | #53 | |
Thanks! | |
| | #55 |
| Authorized Vendor | Good call on throwing up the pics to make it easier. you will need a 14mm for the top with the "flats" and a 12mm for the nut. It takes a little bit of flexibility and patience but you can tighten those without having to rip the whole assembly out. Just drop the front stay and shove it to one side, and that should give you the room. |
| | #56 |
| Spec C Club | This may not be your problem, but it was mine. Still rattle free and loving the TiC's!!! Yay! Fixed that @#%*ing shifter rattle! (PICS) Holy thread resurrection BatMan. |
| | #57 | |
| Authorized Vendor | Quote:
| | #58 |
IWSTI Addict since: Sep 2005 Trader Rating: (5) | Looks like I am going to have to take UrbanKnight's advice. I drove the car with the replacement oring and I still have the rattle. The shifts are tighter and firmer and feel great! The rattle is there, but about half as loud as it was before. |
| | #59 |
IWSTI Addict since: Jun 2005 Trader Rating: (0) | I am buying a sprinkler tomorrow. Thanks man. I blew my amp and now all I hear is the rattle. When I pull on the reverse it stops. Thanks again. |
| | #60 |
| Authorized Vendor | if it stops when you pull on the reverse then you need to adjust the tension in the lockout cable. This ad is not endorsed by this member. Please register or login to hide this ad. |
