Old 06-10-2005, 10:47 AM   #1
IWSTI Addict since: Jan 2005
Default Clutch making a clicking noise
When the car is on, and in neutral at a complete stop
If i press the clutch in and let it out semi fast at idle in neutral, i hear a clicking sound at right about the friction point
if i let the clutch out slow, theres no sound
is this normal?
popnfresh is offline   Reply With Quote
Old 06-11-2005, 09:52 AM   #2
Car: 05 STI
IWSTI Addict since: Dec 2004
I have the same noise as well, Ive had it for awhile and learned to ignore it.
slick50 is offline   Reply With Quote
Old 06-12-2005, 01:18 PM   #3
Car: CGM 05 STI
I have had that same noise with my car since I first got it. I believe its just the clutch release switch. Nuthin to worry about.
darkcrystal05 is offline   Reply With Quote
Old 06-15-2005, 05:39 PM   #4
Car: 05' STi CGM/Silver
Fav Mod: Recaro Sports
IWSTI Addict since: Oct 2004
even at full stop in teutral, the clutch engages and disengages. what your hearing prolly is the clutch grabing with no slip because there is no load on it. just fyi, you can still wear the clutch out at full stop by having it pushed in.
STi05' is offline   Reply With Quote
Old 06-17-2005, 07:56 AM   #5
Fav Mod: driving lessons :)
IWSTI Addict since: Oct 2002
Trader Rating: (12)
Actually, you won't wear out the clutch at a full stop by having the pedal pushed in (as the clutch is not actually doing anything at a full stop). Rather, you'll wear out the throw-out bearing. It's under load when you're at a stop and holding the clutch pedal in.
gesundlich is offline   Reply With Quote
Old 10-12-2006, 02:22 PM   #6
Car: 05 Subaru WRX STi
Fav Mod: Bride Zeta III / Advan RGII >=)
IWSTI Addict since: Jun 2005
is this normal?
bringing this back from the dead...
so has someone ever confirmed that this sound was normal? i just experienced this on my way back from lunch.
SD 05 STi is offline   Reply With Quote
