Old 06-02-2005, 02:32 PM   #1
Fav Mod: driving lessons :)
IWSTI Addict since: Oct 2002
Trader Rating: (12)
Default rear end "clunk"-NOT STRUTS OR DIFF BSHNGS
54,xxx miles on my '04 STi and a new noise. It's a "clunk", or more accurately a "pop" sound (higher in pitch than the diff clunk/thump heard when shifting hard between 1st and 2nd). It's definitely coming from the rear and it's only a single clunk/pop, unlike the multiple "popcorn" noises from the struts. No adverse driving behavior that I've noticed, but it's definitely a noise that wasn't there 20,000 miles ago. Only happens (noticed) when letting off of the gas at slow speeds or accelerating from slow speeds. It's definitely coming from the rear of the car. It can be felt and heard. Essentially, it only happens when weight is transferred fore and aft, or alternatively, when torque is abruptly applied or removed. Subie dealer wasn't helpful in the least. My bet is on either some rear diff mounting point/bushing, something, somewhere in the driveshaft couplings, or perhaps something altogether different. I'd be interesetd in people's theories and, even more so, in their actual diagnosis and solutions. And it's not the rear diff carrier bushings (I have the Whitelines) or strut clunk (just replaced under extended warranty), btw (this is a completely different sound).
Bryan
gesundlich is offline   Reply With Quote
Old 06-02-2005, 02:41 PM   #2
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (54)
Do you happen to have endlinks that use spherical bearings?
Turninconcepts.com is online now   Reply With Quote
Old 06-02-2005, 04:02 PM   #3
Trader Rating: (12)
Yes.... Sitting on my bedroom floor (not installed, yet). I have front and rear Cobb sway bars and Perrin rear end-links that I'm probably going to install this weekend. My entire suspension (with the exception of the Whiteline rear diff carrier bushings) is completely stock and has been the whole time I've owned the car. FYI, the diff bushings have been on my car for over 50,000 miles. This seems to be happening to other STi owners, as well. Several have posted both here and on Nabisco about it as well. No answers for anyone, yet.
By the way, the noise sounds like a quick "kuh" sound, if I had to actually try and reproduce it in words (say it out loud and you'll get an idea of the sound I'm talking about). Quite dissimilar from the pronounced "thunk" from the rear diff during shifts or the "pop-pop-pop-pop" of the struts.
Bryan
Old 06-02-2005, 05:59 PM   #4
Fav Mod: 4th gear wheelspin
IWSTI Addict since: Nov 2004
Is it like what was mentioned in this thread? http://www.imprezawrxsti.com/forums/...ad.php?t=25833
I get a similar noise since about 1000 miles ago, my 05 has 12k miles on it now. It started after a day at the dragstrip when I was getting a lot of wheelhop. I can't believe it is "normal"
Old 06-02-2005, 07:08 PM   #5
Car: 2006 STI
IWSTI Addict since: May 2004
Send a message via AIM to WipeOutXXL
I've been getting that sound since my car had 11,000 miles on it. 2 L7's later, and 3 amps, they are shaking the tears away. Other than that no other problem other than the fact that it's annoying.
WipeOutXXL is offline   Reply With Quote
Old 06-02-2005, 07:42 PM   #6
Trader Rating: (12)
Yep, same as posted in the link above. Interesting. Any one have any theories or solutions? I'm not worried (yet), but the R180 diff isn't cheap to replace (if it is indeed a diff problem at all). Like to hear any others chime in.
Old 06-02-2005, 08:41 PM   #7
Car: 2006 STI
...factory warranty will also wash away the tears...if it is a problem. I'll hand the service guy $100 bucks before it goes out to replace anything under warranty that...."is going to go out".....
Old 06-02-2005, 09:40 PM   #8
Car: 03' EVO VIII
Fav Mod: Moton Clubsports
IWSTI Addict since: Jun 2004
Tomorrow is my appt. with the dealer. Will report back. I'm going to insist on a tech ride along so they can't say "don't know what you're talking about...sounds normal to us".
ChrisF is offline   Reply With Quote
Old 06-03-2005, 09:36 AM   #9
Car: 03' EVO VIII
Glazed look on the service tech's face this am was not confidence inspiring.
Old 06-03-2005, 12:55 PM   #10
Ben
Retired Admin
Fav Mod: Weight Loss
IWSTI Addict since: Dec 1969
Send a message via AIM to Ben
Update to my post here: http://www.imprezawrxsti.com/forums/...620#post267620
Basically, long story short, the noise is normal.
Ben is offline   Reply With Quote
