Old 06-02-2005, 09:20 AM   #1
Rev
STI Guru
Car: 06 V70R
IWSTI Addict since: Dec 2003
Send a message via AIM to Rev
Default How to clean the MAF sensor?
Anyone done this?
I was wondering on doing some preventative maintenance on it ..
Or should I not touch anything unless I see something running rough ...
Any tips as to how to properly clean it? ... I know it's a very delicate part ... so share your thoughts with me
Old 06-03-2005, 12:46 PM   #2
Car: 2006 OBXT
IWSTI Addict since: May 2005
Hey STI Thunder, I'd love to see your ride sometime and meet you, I'm just a town or so away.
When I was a mechanic, we would clean MAF's with a Q-Tip and some rubbing or denatured alcohol, or brake clean. Don't use anything like carb cleaner, it's too harsh and leaves a residue when it dries. Just soak the Q-tip with the cleaner and VERY lightly rub the wire.
On older vehicles we would always opt to replace the sensor.
I personally wouldn't mess with cleaning it, unless your seeing different fuel trims or having drivability problems. The wire is very fragile.
Selrahc is offline   Reply With Quote
Old 06-03-2005, 12:56 PM   #3
Rev
STI Guru
Car: 06 V70R
Carol Stream is a couple miles south indeed ... we'll see ya around
Thanks for your help ... I was thinking about not messing with it Just wanted to make sure ...
Old 06-03-2005, 01:47 PM   #4
Banned
IWSTI Addict since: Oct 2004
fast drying electronic cleaner..comes in a spray can at pepboys..you dont wanna touch the sensor..just spray it and it drys in seconds
Mach1STi is offline   Reply With Quote
Old 06-03-2005, 02:06 PM   #5
Car: 2006 OBXT
+1
This would be the best technique for the "maintenance" cleaning you're looking for. Usually, when I'd see a car in the shop with MAF problems, a simple spray down wouldn't do the trick. A VERY light Q-tip rub would be required. Of course by that time replacement is really in order.
Old 06-03-2005, 09:30 PM   #6
Car: 05' STi CGM/Silver
Fav Mod: Recaro Sports
Wait.. why would it be dirty in the first place? You guys running without airfilters?
Hahaha, Im guess the only build up you would get is filter oil.
STi05' is offline   Reply With Quote
Old 06-03-2005, 10:00 PM   #7
www.Subie.tv is niiice
IWSTI Addict since: Aug 2003
Is it too fragile for that dust off spray sold for computer keyboards?
Old 06-04-2005, 08:01 AM   #8
Visiting NASIOC Timeout
Car: 05 STi + 08 OBXT
Fav Mod: Wingless FTW!
IWSTI Addict since: May 2004
I used non-chlorinated brake cleaner on my WRX's MAF - worked fine. Squirt some in, let it sit for a few moments, dump it out. Just be careful not to strip the soft screws on the MAF housing.
