Old 06-02-2005, 05:38 AM   #1
IWSTI Addict since: Jan 2005
Default stock clutch
Hello everyone. I have an 05 sti, with just over 4k on it. I have never done any street racing or any launches but my clutch feels weird. It engages almost at the top.. maybe i am just used to it, i have tried all the tricks, IE go at 2500 rpm in 5th and floor it and see if RPMS climb and not speed.. no both go up at a good rate.. just not sure. do your guys clutches engage so late? thanks, maybe i am just nervous.
AdamBlitzer is offline   Reply With Quote
Old 06-02-2005, 06:36 AM   #2
Car: 05 Subaru WRX STI CG
IWSTI Addict since: Aug 2003
That sounds about normal. There are ways to remove the ClutchDelayValve and that may help some, but that sounds about right. Mine is an 04 and engages pretty high up.
Robert~
Old 06-02-2005, 06:59 AM   #3
Car: 04/08STI 95SVX 86E30
IWSTI Addict since: Jul 2003
Trader Rating: (54)
I see the same thing as Robert. Engagement is pretty high up. I've been thinking about bleeding the clutch cylinder to see what that does, but have not had the time.
Old 06-02-2005, 07:15 AM   #4
Car: 2005 subaru wrx sti
Fav Mod: TEIN SS COILOVERS
IWSTI Addict since: Aug 2004
Send a message via AIM to taliano95 Send a message via Yahoo to taliano95
sounds pretty normal to me too. I gots me an 05 and it engages pretty high up too.
taliano95 is offline   Reply With Quote
Old 06-02-2005, 06:30 PM   #5
Car: TIC Spec OBP STi
Fav Mod: Cobb AP V2
IWSTI Addict since: Apr 2005
Just curious if you have moved your seat back a little. I noticed I drive much better when i sit up straight, and pull my seat back, and therefore the clutch enages higher than it did when i slouched. Just a thought, i could be way off.
pharo is online now   Reply With Quote
Old 06-02-2005, 06:34 PM   #6
Car: 2005 & 2008 STI
Fav Mod: Scott Siegel Tuning!!! :D
IWSTI Addict since: Mar 2005
Send a message via AIM to JDM-STI Send a message via MSN to JDM-STI
I have an 05 and my clutch engauges at the bottom of the pedal. 3000 miles.
Has since day one.
JDM-STI is offline   Reply With Quote
Old 06-02-2005, 06:56 PM   #7
Car: 05 obp sti
IWSTI Addict since: Nov 2004
mine is up kinda high too...
non-ricer is offline   Reply With Quote
Old 06-03-2005, 05:31 AM   #8
Car: 04 STI
IWSTI Addict since: Nov 2003
mines engages just a tad below the center.
bekster43 is offline   Reply With Quote
Old 06-03-2005, 05:51 AM   #9
hm. welll i wonder if i bring the car to the dealership if they can see how much "wear and tear" is left and has been used. Just wish it was a little lower like my friends m5
Old 06-03-2005, 07:13 AM   #10
is this thing on?
Car: 05 STI - WRB on Gold
IWSTI Addict since: May 2005
I just turned 12,000 miles on my 05. My clutch used egage pretty low, below half way. After a few passes at the track my clutch engages almost at the top. From the smell I'm pretty sure I burnt the clutch pretty good.
[hijack]When should I replace it? When the clutch begins to slip during daily driving? Any thoughts on going to the dealer (under warranty) or aftermarket?[/hijack]
silverbetty is offline   Reply With Quote
Old 06-03-2005, 01:56 PM   #11
Fav Mod: driving lessons :)
IWSTI Addict since: Oct 2002
Trader Rating: (12)
I disagree. I'm at 54,xxx miles, 45,000 of those with the AP stg 2, full exhaust, etc. Numerous drag visits and several track days. Mine engaged at the top of its travel when new, and continues to engage at the same place. Never even a single sign of slippage (although it has ALWAYS had a small amount of shudder when first taking off from a stop in the morning). My .02
gesundlich is offline   Reply With Quote
Old 06-08-2005, 06:24 AM   #12
RG
Car: Blue/Gold 05 STi
This is strange that people's clutches are enganging at different points. Mine starts to engage about half an inch off the floor.
RG is offline   Reply With Quote
Old 06-08-2005, 06:32 AM   #13
Fav Mod: IT
People have different ideas about what the engagement point is. I.e. even on the same car people would place it differently. The clutch *is* a pedal, not an on/off switch so the determination is a bit subjective. I place it where in about 5th gear at 45mph with about 1/3 throttle how far I have to press before it runs away. It's only about 2 inches depressed.
I tend to think the STi is a bit high in the pedal travel. Sure it starts to have a tiny bit of friction right off the floor, but not enough to do anything but crawl gridlock in 1st gear.
Freon is offline   Reply With Quote
