| | #16 |
| Amateur STI Driver | best way to stop this car is mash on the brakes.. the ABS will do the work. as for engine breaking along with the brakes... save your clutch.. car's brake distance depends on friction between tires and road not how big the brake is.. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #18 |
| STI Driver Car: 2008 A4 6MT LOADED Fav Mod: I miss my Subaru... Location: Chino Hills, CA Posts: 238
IWSTI Addict since: Jul 2005 Trader Rating: (2) | if u slow down on gear it will not mess up anything on your car, as long as u stay in the proper rpm band... it will make weird sounds as the clutch is slowing the gear down... and another thing.. this is an STi... put it on neutral goin downhill at 80 mph and have the confidence that the car will handle just fine.. |
| | #19 | |
| Spec C Club Car: 05 WRX STi Fav Mod: Hate Location: Floridrizzle Posts: 1,067
IWSTI Addict since: May 2005 Trader Rating: (6) | Quote:
_Franklin | |
| | #21 | |
| Senior STI Driver | Quote:
-spyder dont quote me on anything | |
| | #22 |
| Junior STI Driver Car: LandShark STi Fav Mod: GT40R Location: DFW Posts: 122
IWSTI Addict since: Aug 2004 Trader Rating: (0) | For almost every car, the most powerfull force it can apply is negative acceleration via the brakes. How quickly you'll be able to stop is mostly dependent upon the tires, and how much grip they have on the ground. Modern hydraulic brake systems don't have much trouble exceeding this limit. If you're only trying to slow down, engine braking will not help you stop quicker. Now if you loose your brakes, the situation may be different. This ad is not endorsed by this member. Please register or login to hide this ad. |
