Old 05-29-2003, 01:28 PM   #16
Fav Mod: Computer Programmer
Originally Posted by ingraham
Well I must say BHodges your new avitar is you best so far, and most annoying
Muhahah! You think this one is bad....wait until I spread my evil avatars to all. I got one for ya right now as a matter of fact....
BHODGES3 is offline   Reply With Quote
Old 05-29-2003, 06:45 PM   #17
Car: Solo II, WRC
Send a message via AIM to CloNeGTS
Default Grab my spot in Colorado
Uh....before this gets out of hand.....I think you should change the one you have up now. That certainly isn't what I'd call a 'safe at work' image. Can ya do that for us? Thanks.
CloNeGTS is offline   Reply With Quote
Old 05-30-2003, 07:10 AM   #18
Heh, sure...
Old 06-15-2003, 06:22 PM   #19
why not just step and let go quicklyof the gas at 3k rpm and stop the car before let go, so the oil goes away at the split second
cann is offline   Reply With Quote
Old 06-15-2003, 07:12 PM   #20
Default Evo 8 Message Boards?
From the STi service manual (same as the WRX):
B: TURBOCHARGER UNIT
The turbocharger is water-cooled. It utilizes a wastegate valve to adjust its supercharging pressure to an optimum level. ...
C: LUBRICATION OF TURBOCHARGER
The turbocharger is lubricated by engine oil branched out from the oil pump. To cope with very high speed of the turbocharger turbine and the compressor shaft which may reach a maximum of several hundred thousands of rpm, full-floating type bearings are used which can form adequate oil films on their inside and outside during running. Further the oil supplied to the turbocharger also plays a role of cooling the turbine so that heat from exhaust gas does not transmitted to the bearings.
D: COOLING OF TURBOCHARGER
The turbocharger unit is cooled by engine coolant, which enhances the reliability and durability of the unit. The engine coolant from the coolant drain hose located under the cylinder head is led by a pipe to the coolant passage provided in the turbocharger bearing housing. After cooling the bearing housing, the engine coolant is led into the coolant filler tank through a pipe.
RDiamond is offline   Reply With Quote
Old 06-15-2003, 08:40 PM   #21
Use a full synthetic oil such as Mobil 1. This will prevent any possibility of coking which the turbo timer is used to prevent. Coking is where the oil breaks down from heat and is no longer oil. Full synthetics, not blends, have a much higher heat tolerance than regular organic based oil. Buick Grand Nationals which did not have water cooling never had any problems using such oils.
gasguzzler259 is offline   Reply With Quote
Old 06-16-2003, 11:03 AM   #22
Some more insight from Mike Shields (a long-time Subie tuner):
The Subaru WRX engines have their water catch tank high on the engine above the turbocharger. When the engine is shut off the water continues to circulate via a physical property of water called a thermal siphon. Simply put, hot water rises up to the catch tank, being drawn from the relatively cool cylinder head water jacket up through the turbo housing. One still needs to take a cool down lap at the track and perhaps should not stop at the top of a mountain pass to enjoy the view if you have been on the boost all the way up, but for the other 99% of the time there is no need to let the engine idle for a minute before shutting off ignition. Even when the engine is off, the cooling water will circulate past the turbine bearing housing.
http://www.spdusa.com/engine_modification.htm
