Old 06-22-2008, 02:21 PM   #1
Car: WRB/carbon 05 STi
Default Rear end clunking?
it started off easy and i noticed it from time to time, then it progressively got worse and worse. not i hear it any time i get on or off the gas. it sounds like a U joint issue, i jacked it up and there was no play in the DS or axles. so now its down to the rear end about to blow up, or shot bushings/mount on the rear diff. the car has 36k on it, and its not babied. i noticed it like two months ago and not its to the point where i am just waiting for something to snap. if i'm just driving and tap the gas for a second, i hear it when the power hits, then again when i let off. sounds to me like a ready to blow rear, but i'm hoping someone will tell me its just the bushings and be right.
IgotAsweetRide is offline   Reply With Quote
Old 06-22-2008, 03:19 PM   #2
Fav Mod: Motor Mounts
Default Re: Rear end clunking?
Probably the rear struts...search strut clunk...
Old 06-22-2008, 03:37 PM   #3
after i posted, i knew i should have added that in. they were just replaced and its deff related to the throttle and not suspension. i jacked the car up and rotated the wheel back and forth and heard a slight clunking from the tailshaft of the tranny. has anyone had problems with the teeth wearing out somehow? at this point i want to just take it to the track and launch it so something with break and i can just fix it and move on.
Old 06-22-2008, 07:22 PM   #4
Have you checked the motor mounts?
Old 06-23-2008, 01:20 AM   #5
nope, didn't think of it because its sounded like it was deff the rear, but i'll check them to make sure.
Old 06-23-2008, 10:30 AM   #6
It is totally possible that the rear-dif is blown...change the oil out and look for metal shards or chunks of metal in the oil. Good luck.
Old 06-23-2008, 12:27 PM   #7
well, i am now stumped. the clunk is gone. maybe the rear was loose in the bracket somehow and me jacking it up put it back in place? i was planning on changing all the fluids, i just have to order the good stuff and hope TIC gets their rear end klunk kit back in stock soon and hopefully the noise never comes back.
Old 06-23-2008, 12:30 PM   #8
check the exhaust hangers too. Over time they get soft and dont hold strong. They can let the muffler hit the heatshield in the back and make a clunk. Just shake you tip as hard as you can, you might hear the dreded noise. Good luck!
Old 06-23-2008, 12:36 PM   #9
i eat cones
Fav Mod: 18x8
Trader Rating: (18)
strut clunkkkkkkkkkkkkkkkk. i think im getting it now too...
Old 06-23-2008, 12:41 PM   #10
Car: 04 Subaru WRX STi -
Another possibility to search on is the Rear Axle Nuts. When bad, you'll get a cluck sound when you cahnge the acceleration rate such as when shifting, quickly letting off the gas, going into reverse, etc. I had this problem and it has completely gone away once the nuts were replaced.
RenoSTi is offline   Reply With Quote
