Old 06-19-2008, 08:11 AM   #1
Car: Grey 07 STi
Fav Mod: Gas into the tank
Default Engine reving high at 3.3k+ RPM
Sorry if this has been addressed somewhere else.
So my problem is that at arround 3k rpm, where the turbo normally begins to do its work, the engine suddenly spikes in revs to about 7k or so. The feeling is the same as if the clutch was depressed during a hard pull. There is no feedback to the tires, and speed stays the same, but suddenly the rpms spike. Normally I would just peg it as the clutch going out, but testing the 6th gear, go from 20 mph thing I have no problems.
So in any gear, when I hit about 3k+ rpm, the engine revs like I hit the clutch, but the clutch doesnt seem to be going out.
I dont track the car, nor do I race.
Thoughts? Help? Before I throw myself on the mercy of the mechanic?
Thanks.
Rambler is offline   Reply With Quote
Old 06-19-2008, 08:21 AM   #2
Fav Mod: Me!
Default Re: Engine reving high at 3.3k+ RPM
put the car into 6th gear and floor it. If the RPM's spike your clutch is going out. Sounds to me like its slipping.
Old 06-19-2008, 08:22 AM   #3
Car: 07 STi Blue
Fav Mod: stock :]
wow good luck :[
bue car is offline   Reply With Quote
Old 06-19-2008, 08:27 AM   #4
Car: Grey 07 STi
Sorry, guess I should have made this clear heh. I did this as soon as it started (pulled over into a parking lot like lol). Nothing. No RPM spike or anything from being in 6th and flooring it. So I am puzzled.
Thanks for the response though.
Thanks for the luck Bue car
Old 06-19-2008, 08:29 AM   #5
Fav Mod: I do meth...
It's the clutch.
6th at 20 mph I doubt would be making enough power to slip the clutch.
renns is offline   Reply With Quote
Old 06-19-2008, 08:31 AM   #6
Car: Grey 07 STi
Originally Posted by renns View Post
It's the clutch.
I had it up to about 50ish before I ran out of parking lot heh.
So most likely clutch eh? Any hope I can wrangle something out under warentee?
Old 06-19-2008, 08:32 AM   #7
Depends on the mods on the car.
If you don't have any I bet you could get a free one... but probably only one so be careful with how you drive.
How many miles on the car?
Old 06-19-2008, 08:49 AM   #8
Car: Grey 07 STi
No mods at all.
Right at 31000 miles.
Old 06-19-2008, 09:01 AM   #9
It's worth a shot. 31k seems a little bit higher that what they might replace do to defect, but I don't know.
The worst that could happen is that you'll have to buy a new clutch... which isn't that big a deal.
Old 06-19-2008, 09:57 AM   #10
Fav Mod: CarComfortDesign@Gmail.com
Subaru covers all wear items under the 3yr/36K warranty. As long as you dont have any mods and do not abuse the car, (ie. hard launches, poor driving habits) then they will cover your brakes, clutch, tires, wiper blades, etc...) Just go in and have them check it out.
good luck.
Jay
JZeezSTi is offline   Reply With Quote
Old 06-19-2008, 10:46 AM   #11
Fav Mod: Me!
Hit the highway/freeway. Go about 65/70 MPH and then floor it in 6th. If your RPM's spike, your clutch is slipping. When your clutch slips it usually effects the higher gears first. That being said, since you have a 07 with under 36k miles I would just goto the dealership and have it warranted.
Old 06-19-2008, 11:07 AM   #12
Car: Grey 07 STi
Thanks so much for the replies. I checked it at 6th going faster, and yah, its more of the same. So I will take it in to Subaru, get some use out of the warranty.
Thanks
