Old 06-18-2008, 07:57 PM   #1
Car: WR blue 04 STI
Fav Mod: train horn/gun rack
Default clutch drop broke the dccd maybe?
hey i have a 2004 sti . any way last night missing around i droped the clutch being dum, to do a quick turn around(showing off to my evo friend) and a loud bang came from under the back seatand the car stoped moveing 1,2,3,4,6,r do not work unless i turn my dccd to lock. i looked at all my cv all good . drive line ok, rear end ok, and so on so i decided to pull the trany thinking the clutch was gone haveing only 3000 miles on it. there was nothing wrong with it gears all seam to be fine when driveing with it in lock. now if it isnt in lock it makes a whiny nose and trys to move but dose not in any gear.has any one ever blown a dccd unit up ? any way just woundering what u think guys o ya i pulled my top mount off to put in my new turbo and my pitch arm mount was broke
montanarally is offline   Reply With Quote
Old 06-18-2008, 09:21 PM   #2
Car: WRB 05 WRX STi
Fav Mod: Easter Bunny
Default Re: clutch drop broke the dccd maybe?
YouTube - STi 0-60MPH Test - AWD Burnouts!
Like the sound at the end of this video.."awww.......its crying" makes me laugh everytime and cry bec. of the abuse.
He breaks something at the end trust me, it makes the whining sound just listen.
Toofast22 is offline   Reply With Quote
Old 06-19-2008, 04:48 AM   #3
Reasonable
Fav Mod: correct grammar
Sounds like the center diff is borked.
Old 06-19-2008, 05:00 AM   #4
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
an axle?
Old 06-19-2008, 05:02 AM   #5
Car: STIzzle
Fav Mod: Tint
+1 "awww.......its crying" <-- This is going to make my day!
Old 06-19-2008, 05:03 AM   #6
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
I'm guessing it's a diff on either end based on the fact that it will drive in lock. If he had blown the center diff, it wouldn't go anywhere regardless of setting.
Old 06-19-2008, 05:08 AM   #7
Reasonable
Oh yeah. I suppose I should wake up before posting.
Old 06-19-2008, 05:24 AM   #8
abracious
Fav Mod: Track time
My bet is on a broken rear axle. Our DCCDs are pretty bulletproof and axles go first.
This is why you should no upgrade axles unless you are ready to break more expensive parts.
Where is it crying from?
Old 06-19-2008, 06:31 AM   #9
Car: '08 335xi Coupe
Fav Mod: Dinan Reflash
You could have broken quite a few things including axles and diffs. So get yourself to a qualified mechanic and quickly. I also agree with Lack that its probably not a center diff issue or tranny issue as you said it drives O.K. in lock. But that leaves 2 diffs and 4 axles. I am betting (hypothetically) that its a rear axle though.
Old 06-19-2008, 09:18 AM   #10
Car: WR blue 04 STI
wow its sounds just like my car. but i have all 4 cv in front of me all good and i just got done puting in my new rally def in the rear last night and it looked good. it hold alot of oil now. im kinda stuck doing it my self as far as takeing it any were our dealer here has had to send my car off to have new motor new trany put in because they muffed up on it and could now fix it last year. so there never touching her. dose any one know for shure what he broke? thanks i think it might be the front or the dccd i have the break down on it shows a cluth on each end of the unit so maybe i burnt that up?
Old 06-19-2008, 03:55 PM   #11
Car: 05 STi CGM Stg2
have u tried putting the car on jack stands and popping it in gear and letting it run and then trying to slow one wheel at a time some how but safely...
Old 06-19-2008, 05:21 PM   #12
Fav Mod: The Newest One!
That would be my guess as well.
Old 06-19-2008, 05:23 PM   #13
abracious
Fav Mod: Track time
This won't do much as our diffs require friction to limit slip.
Old 06-19-2008, 05:30 PM   #14
Car: WRB 05 WRX STi
same here cause if its the same sound as the video thats what that guy did broke his axle.
Old 06-19-2008, 05:48 PM   #15
Hence why i said try to slow one wheel (safely)
If the f/r diff's are borked then you have a slight chance of seeing that front end or one wheel is slow to spin or may not even spin...its worth a shot...takes 5 mins to get the car up on jack stands...maybe spend an hour diagnosing
I dont know its something I would do to diagnose further
