Old 06-18-2008, 03:40 PM   #1
Car: 04 WRX 'blk prl' STi
Fav Mod: Injen CAI w/ used filter :D
Default Clutches for ACT ProLite
Hey all. One day at the track and here i am sick with mods
My question is what clutches will work with this flywheel. The ACT ones are a given, what about other ones?
Can those of you running the ProLite provide some feedback/advice on how different clutches work with it?
all help and advice is greatly appreciated.
thanks,
-alex
sti_schumacher is offline   Reply With Quote
Old 06-19-2008, 01:23 AM   #2
Car: 05 STi CGM
Fav Mod: whiskey tango
Default Re: Clutches for ACT ProLite
Most all clutches are designed to work with the factory bolt pattern on the OEM flywheel. As a result most if not all clutches should work. RPS, SPEC, clutchmasters, cencterforce, etc. Unless I have missed something most brands will work.
Old 06-22-2008, 10:08 AM   #3
Car: 2008 STI
Send a message via AIM to FlyingPerformance
do you already have the pro-lite flywheel? If not, every manufacturer makes a lightweight flywheel. You could mix and match, but I personally would not recommend it. ACT makes great clutches so if you already have the flywheel I would stick with them. PM me if you want some pricing.
FlyingPerformance is online now   Reply With Quote
Old 06-22-2008, 10:41 AM   #4
its all in the curves
Fav Mod: Aps 3.5" TBE
just a heads up on the prolite, from what i've heard since it is so light compared to the oem it tends to throw cel's.
sti_kris is offline   Reply With Quote
Old 06-22-2008, 11:34 AM   #5
thanks for the help guys. it really got me thinking.
i've actually started having some 2nd thoughts about this flywheel-->
i've read several threads about lighweight flywheels. i found out that there arise issues with engine longevity with lightweight flywheels. specifically, the OEM flywheel has a specific amount of weight put into it to maintain engine balance. if the weight is not there, engine vibration can result - the crank-line may spin at the incorrect speed, which causes the angle of the force exerted by the piston rod onto the crankshaft to be at the incorrect angle. this causes vibration and takes a toll on the crank bearings. for the same reason, it is not beneficial for engine longevity to run a lightened crank pulley, especially with a lighweight flywheel. lighweight pulleys also lack an overlooked feature of the stock pulley - a dampener, which actually suppresses the engine vibrations.
so too light is not always too good when it comes to engine components.
^let me know if that makes sense, cause it does to me.
im now thinking about the streetlite flywheel, but im guessing that the same clutches will work for it as the OEM and streetlite flywheels.
Old 06-23-2008, 05:25 AM   #6
Fav Mod: Synapse FMIC
I ran an ACT Prolite with an RPS spung 6-puck. Loved it besides the fact that I stalled the car every day and couldn't get a decent launch due to the flywheel. I'm switching back to an OEM flywheel now....
