Old 06-11-2008, 01:24 PM   #16
Car: 04 psm sti
Default Re: how strong is the stock clutch?
Originally Posted by ChristianCGM View Post
There are no specific clamp load or torque capacity numbers for the stock clutch assembly, but the clutch is made by Exedy. The Stage 1 'upgrade' from stock is an organic disk that holds 321 ft/lbs. Now if you take into account 25% drivetrain loss for AWD then you are left at 241 ft/lbs at the wheels. Now if you have a tuned stage 2 that is not going to be enough as most people are making somewhere around 310-325 wtq. Again take into account drivetrain loss, but calculating flywheel torque capacity (using 310wtq) you will need a clutch that will hold 413 ft/lbs at the flywheel. If the Exedy Stage 1 is an upgrade and it is not substantial enough, think how inadequate the stock equipment is to handle a tuned stage 2 STi....just some food for thought.
I have the Exedy stage 1 on my car which is protuned stage 2. The car makes just under 300whp, but makes 370wtq. I'd say the clutch has about 7k miles on it at that level of tune. I've launched it maybe a handful of times b/c I don't want to kill it. I am slightly concerned that if I take the car up another level perhaps with a 20g or a Green, that the clutch is bye bye. Having driven the car with a stock clutch and stage 2 tuning, I would be apprehensive about leaving that clutch in there. But other people have had results that say otherwise.Just my .02
whifkey Sti is offline   Reply With Quote
Old 06-11-2008, 01:37 PM   #17
Car: 04 WRB sti
wich clutch do you guys think is the best for a gt35r set up making 400whp+
lapinga is online now   Reply With Quote
Old 06-11-2008, 02:47 PM   #18
Car: 05 OBP STi
Fav Mod: B&B Exhaust
Originally Posted by JZeezSTi View Post
maybe its your driving... not trying to be a jerk. But maybe something you do when your daily driving your car is wearing your clutch faster.
No offense taken, the first thought usually is driver error, but for the 14k I've driven it I think I've been easy on the clutch. No hard launches, no sitting at a light in first gear w/ the clutch in, no resting my foot on the pedal, etc. I always rev match, double clutch, and generally try to drive smoothly.
I think it was a combination of descending from 7000 ft. to sea level that day (engine braking) followed by sitting in 90+ degree LA traffic that warped the clutch enough to damage it. It's not worn down (e.g. slipping), it's just messed up badly and the feel is all wrong. I just would think it would be tougher. I'm mostly mad b/c I don't have the money to fix it right now (student) .
That and my friend in his 07 STi did the same drive w/ me and didn't have any problems.
xnthuzst is offline   Reply With Quote
Old 06-11-2008, 09:30 PM   #19
Car: 05 STi CGM
Fav Mod: whiskey tango
I am just here to spit out numbers. Numbers don't lie when I comes down to how much the clutch is rated at and how much of that is applicable to various power outputs of differing stage 2 and stage 2+ tunes. However, people do tend to embellish and create extravagances of their driving habits with relation to brand-X clutch holding xxx-wtq.....this is more of a generalization on my part and not directed to anyone specifically. Clutches want to grab and over time with a torque power number higher than its rated than the frictional resistance of the assembly lessens and lessens until....well it ain't got no mo to give. Don't forget that the more power that you make the stronger the clutch you need and with that the clutch engagement is going to become less and less comfortable.
Old 06-12-2008, 07:43 AM   #20
Car: 06 Subaru STi
Fav Mod: Deadbolt 20G
I have a 20G on my 06 STi which is putting 350hp/370tq. to the ground. I only have a little over 13,000 miles on it, but my clutch feels fine. However, I'm 51, and I don't launch, race ( except by myself ), autocross, or anything else that's hard on it. Most times, if the clutch makes it through tune on the dyno, it will be fine.
Okeyd57 is offline   Reply With Quote
