Old 05-29-2008, 08:34 PM   #1
Car: 2006 AW STi
Fav Mod: Stage 2...so far...
Default Rear Differential Problem??
Now I just traded in my 06 WRX for the 06 STi a couple of weeks ago and put in my exhaust and other under-the-car mods Tuesday. When doing so I noticed that the rear differential seemed to have a sort of dirty fluid similar to that of oil or other engine bay fluids. What is this fluid and should I be worried that my rear diff. is "leaking?"
biker921 is offline   Reply With Quote
Old 05-29-2008, 11:24 PM   #2
Car: 05 CGM STI w/goldies
Fav Mod: Advan A048's
Default Re: Rear Differential Problem??
it's gear oil (80-90w), and it shouldn't be leaking. without any pics it's hard to say, but i would say have your dealer check it out asap, good luck!
crf-sti is offline   Reply With Quote
Old 05-30-2008, 08:42 AM   #3
Car: 2006 AW STi
Here's the pictures I shot today.
Old 05-30-2008, 08:49 AM   #4
Car: 08 STi, SSM
Either that diff cover needs tightening or somebody pulled those axles out during a suspension swap. Check the fluid levels ASAP, no, yesterday. If it is low, get some Subaru LSD fluid and throw it in there. Don't break your temperature probe.
Old 05-30-2008, 09:52 AM   #5
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
That's nothing bad, and looks about normal. It's just residual coming out the vent at the top. If it were wet, and all over stuff then I'd be concerned.
Old 05-30-2008, 11:02 AM   #6
Fav Mod: Motor Mounts
Yeah, do you see any oil on pavement were you park?
