Old 05-28-2008, 07:46 AM   #1
Default Can anyone help me with the part number for the transmission drain plug?
Hi,
I recently rounded the the drain plug when changing the transmission fluid on my '05 STI. It's the 14 mm oil pan side bolt, basically the same issue shown here:
Stripped/destroyed Tranny Drain plug
So now I need to order a new one from the dealer. Does anyone happen to have the part number for this? I want to make sure they don't screw something up and give me the wrong part. Thanks.
P.S.
If you also have the part number for the clutch side 21 mm drain bolt, that would be appreciated as well. I don't actually need a new one at this point but figure it might not be a bad idea to pick one up at the same time just in case I do something stupid down the line.
cyber_x is offline   Reply With Quote
