Old 05-22-2008, 04:51 PM   #1
Car: wrb 05 sti
Fav Mod: my future DOM III+ METH
Default grinding 4th on down shift any suggestions?
hello STi experts! i have a minor problem, when going through the gears 1-6 i have no problem(or grinding) shifting, but when i down shift from 5th or 6th into 4th gear it grinds but still slips into 4th gear; any idea why it would be doing this? if im in 6th gear and i depress the clutch put it in 3rd(still holding the clutch) and then put into 4th gear it does not grind, but from 5th or 6th into 4th it grinds.
subysti5486 is offline   Reply With Quote
Old 05-22-2008, 04:55 PM   #2
Car: JBP 04 STi
Fav Mod: 17x9" on 245's ;)
Send a message via AIM to ATTI2D
Default Re: grinding 4th on down shift any suggestions?
Prolly a syncro. If your under 60k its coverd by warranty.
ATTI2D is offline   Reply With Quote
Old 05-22-2008, 05:01 PM   #3
Car: wrb 05 sti
well i thought about the synchro but i have absolutely no problem up shifting into 4th its only when i down shift into 4th you think its still the synchro?
Old 05-22-2008, 06:42 PM   #4
Car: The Vroom-mobile
Fav Mod: JDM Gears
if it starts getting worse and worse its the syncro, i had mine go out at 36000 and replaced all my syncros with carbon plated ones since my 04 didnt have them. While i was at it i got hardened JDM gears and billet shifter forks
Old 05-23-2008, 03:52 AM   #5
Car: 05 Blue STI
Fav Mod: -10 degree C Ambient Air.. :) Still under warranty!
Can you PM me a link to where you bought those syncros?
xSTIx is offline   Reply With Quote
Old 05-23-2008, 05:42 AM   #6
Fav Mod: so far? RCE T2s
ditto please. I'm way past 60k and the synchros are not doing their job any longer in 4th and 5th.
Old 05-23-2008, 06:33 AM   #7
Car: wrb 05 sti
how much did it cost to get them replaced? i have 22,XXX miles you think its covered under warranty?
Old 05-23-2008, 09:25 AM   #8
Fav Mod: JDM Gears
I had alot of transmission work done so i'm not really sure if its covered under warranty. I basicly i have an 06 JDM tranny now.
z1auto sells the complete set
Z-1 Performance Automotive Services Inc. - STi JDM Upgrade Kit 6 Speed
Old 05-23-2008, 09:49 AM   #9
Fav Mod: BOV and MBC
I had the same problem. Switched to Motul gear oil and it went away...
forget your syncros, unless your under warranty thats some serious cash.
Downshift into 4th....Grind???
Old 05-23-2008, 10:50 AM   #10
Fav Mod: JDM Gears
I heard Motul "revitalizes" the syncros. If it still occurs after tryinng the Motul i suggest replacing the syncros. Mine got to the point where i can slip it into fourth but the second i apply any throttle it would fly out and grind, after if i just let out the clutch fourth wouldnt even stay in.
Old 05-23-2008, 12:55 PM   #11
Car: JBP 04 STi
Replace your syncros under warranty and give Subaru the motul to put in.
Old 05-24-2008, 08:21 PM   #12
Car: 08 Subaru STI
As I've posted here, I have exactly the opposite problem on a new 08 STI: when I upshift from 3rd the 4th, and only then, I have a very occasional grind ("very occasional" = once every several days, where a typical day might be around 75 miles or so, many on back roads).
My dealer replaced the gear oil with the Subaru Extra-S, and that seemed to help -- some. Before that change I was getting the grind a couple of times a day; now, about 1000 miles later, I'm getting it only every couple of days.
I understand that its probably a synchro problem if it gets worse, but what if it doesn't get worse? Should I try the magic Motul? Also, the problem is that Subaru is not going to replace the synchro, or even tear down the transmission to look, in less they can experience the problem for themselves, but this will be hard given the infrequency of the problem. Not sure what, if anything, to do....
Crozetian is offline   Reply With Quote
Old 05-25-2008, 06:25 AM   #13
Fav Mod: 255's ftmfw
Send a message via AIM to sticop
so does that kit just come with parts for 5th and 6th? and is sounds like the highspeed kit comes with 2nd-6th?
none of that helps my 1st gear syncro problem
sticop is offline   Reply With Quote
