Old 05-08-2008, 06:17 PM   #1
Car: Blue 07 WRX STi
Fav Mod: Stage 2
Default What is the best clutch and flywheel for STI 07 stage 2?
subaru_sti293 is offline   Reply With Quote
Old 05-08-2008, 07:13 PM   #2
Car: 04 Sti Wrb on Silver
Default Re: What is the best clutch and flywheel for STI 07 stage 2?
Act street light or even the oem one. Do stock Flywheel, take it to be resurfaced.
Old 05-08-2008, 07:49 PM   #3
Fav Mod: Motor Mounts
Oem...
Old 05-08-2008, 10:01 PM   #4
Car: 06 Subaru WRX STI
The stock one............. it's only stage 2
cnguyen is offline   Reply With Quote
Old 05-09-2008, 05:11 AM   #5
Car: 05 STi CGM
Fav Mod: whiskey tango
Can someone please enlighten me as to why an oem clutch and pressure plate should be used on a car that is not stock? The oem disk is not the problem, the oem pressure plate is the problem....its junk for everything but a stock car. As much as I have read about clutches and pressure plates across different car brands Exedy pressure plates are always overrated compared to their actual torque capacity. If the OP's clutch is slipping and he has a MY07 he obviously drives his car hard. So what would be the point of another stock clutch, it would just slip again.
OP, for anything from Stage 2 to a race-gas tuned GT30R a ACT HDSS or RPS Max Series organic disk clutches will do the job and not have a problem with slipping. For anything above that go with a ACT or RPS sprung 6-puck and stay away from anything twin or tripled plate. I say that because a sprung puck clutch will have the same if not better drivability as a multi plate clutch and when it comes time to replace it you are just replacing a $7-800 clutch as opposed to a clutch that costs 2-3x more than that for the same performance and livability.....as far as flywheel, stock resurfaced
Old 05-09-2008, 06:09 AM   #6
All I know is I abused my clutch stage 2+ and it lasted for more that 50K
Old 05-15-2008, 07:17 AM   #7
Fav Mod: Stage 2
Thanks for the advice man. I always go to 1/4 miles racing maybe i need a new clutch and flywheel lightweight.
Old 05-15-2008, 07:46 AM   #8
Car: The Vroom-mobile
Fav Mod: JDM Gears
If you like to drag, look at what a lighter flywheel does, it changes the way you launch the car.
