Old 04-29-2008, 02:43 PM   #1
Fav Mod: 'STi' Licence Plate! w00t w00t
Default Hard getting into 1st and 5th
Sometimes while driving I cannot get into 1st gear. It just wont go in. After letting off the clutch and trying again, it seems to work. Also when I put it into 5th sometimes it vibrates and makes a god awful noise, almost like it is grinding. I was told before it might be the synchros. Is this something I should be worried about?
Old 04-29-2008, 02:50 PM   #2
Fav Mod: Synapse FMIC
Default Re: Hard getting into 1st and 5th
Typical syncro wear... my 2nd gear and 5th gear grind occasionally. You can try changing the tranny fluid but be careful with which fluid you choose. You will need to double clutch/rev match in order to downshift into 1st while moving from higher speeds. Let the clutch out in neutral, rev to approx rpm you should be in gear, clutch down, and it should slide right in.
Old 04-29-2008, 02:56 PM   #3
Car: The Vroom-mobile
Fav Mod: JDM Gears
sounds like syncros to me! eventually the gear wont even stay engauged
KiTsuNe is online now   Reply With Quote
Old 04-29-2008, 03:00 PM   #4
Car: 04 WRB STi
Fav Mod: JDM STi Recaros
Syncros, 04s have a bad 5th gear that usually needs to be replaced. I had mine done (even outside of warranty) by the dealer 6k ago.
yakmasterjack is offline   Reply With Quote
Old 04-29-2008, 03:09 PM   #5
Fav Mod: JDM Gears
i have replaced 4th 5th and 6th in MY04
Old 04-29-2008, 03:10 PM   #6
05 as well. 06+ got better syncros. I drove one the other day and it was a big difference.
Old 04-29-2008, 07:14 PM   #7
Fav Mod: 255's ftmfw
Send a message via AIM to sticop
ye i think my 1st gear syncro is going I have to pray that I can find a mod friendly dealership around here
sticop is offline   Reply With Quote
Old 04-29-2008, 07:31 PM   #8
Does anyone know what the cost is to have this done not under warranty?
Old 04-29-2008, 07:44 PM   #9
Car: 03 Subaru WRX
Fav Mod: Angry Pig...
Send a message via AIM to Garo666 Send a message via Skype™ to Garo666
lol mine does this alot in first and reverse, and whats even better is that when i do get it into first the whole tranny shakes
Im pretty sure my syncros are way past their life expectancy but watever...
Garo666 is offline   Reply With Quote
Old 04-30-2008, 05:00 AM   #10
Fav Mod: JDM Gears
i believe i paid about 1500 when i had it done
Old 04-30-2008, 08:42 AM   #11
Thanks.
