Old 04-24-2008, 12:46 PM   #1
Fav Mod: 'STi' Licence Plate! w00t w00t
Default slipping clutch
Could someone explain to me what it is ment by the clutch "Slipping." This is my 1st manual car and I just want to know what to lookout for. Thanks!
Old 04-24-2008, 12:58 PM   #2
Fav Mod: I do meth...
Default Re: slipping clutch
Typically it would mean that if you put load on it in a higher gear, the revs would climb and your speed would remain stationary.
The clutch disc spins on the flywheel because it can no longer hold the torque is what actually happens.
renns is offline   Reply With Quote
Old 04-24-2008, 07:01 PM   #3
Fav Mod: Motor Mounts
Put your car into 6th gear @ 60mph and floor the gas...if your revs skyrocket then your clutch is slipping.
Old 04-24-2008, 07:12 PM   #4
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Here's how it works.
on the crank you have a flywheel. The outter surface on the flywheel is machined so that it looks like a brake rotor.
On the tranny input shaft you have the pressure plate. This also has a rotor like surface on it, but also has the diaphram spring (really just a bunch of finger shaped springs arranged in a circle). the spring is what allow the pressure plate to to move in toward the flywheel.
Now, just like your brakes metal on metal contact is bad so you need a friction surface. On your brakes the pads to a really good job of this. In the case of a clutch think of it as a two sided brake pad with pad material on both sides (you have two rotors remember) and shaped like a doughnut. this gets clamped between the flywheel and pressure plate when you release the clutch pedal.
Just like brake pads things wear out over time, and just like brake pads they will wear faster the harder you are on them.
When a clutch slips it means one of the metal surfaces (usually flywheel side) is slipping on the face of the clutch disk (the doughnut).
the end result is an engine that revs without spinning the input shaft of the transmission as well as it should.
What you will see in the car is a jump in RPMs, but no surge forward. it will start in the higher gears, and as it wears out even more will start to slip in the lower gears.
Turninconcepts.com is online now   Reply With Quote
Old 04-24-2008, 09:22 PM   #5
I will try that 60mph 6th gear thing tomorrow. I dont know if this is related or not, but I have a sensor box that bolts into the dash like a CD player Link here Psi3 - ECU Data Monitors. - Subaru Single DIN LCD Data Monitor
When I am in 5th or 6th gear and I stomp on the gas, I get a High Boost Pressure warning. Should I worry about that?
