Old 04-22-2008, 03:27 PM   #1
Car: 07 Subaru WRX STi Bl
Fav Mod: APS INTAKE
Send a message via Yahoo to manny07sti
Default Clutch replaced under warranty. Due to pedal vibration.PICS
I just started experiencing a vibration on my clutch under load. Its been goin on for out 100miles. When the car is out of gear and clutch press there is no vibration. But when clutch is pressed and in gear the vibration gets worse. It even gets worse when RPM's get higher. Went to my local dealer and problem is more than likely clutch through-out bearing. So its covered under warranty. Anyone experienced this before?
Thanks
Manny Z
manny07sti is offline   Reply With Quote
Old 04-22-2008, 03:28 PM   #2
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Default Re: Clutch Pedal Vibration under load. Warranty issue.
Thanks
Manny Z
Weird....you'd feel/hear it if it was in gear or not.
Old 04-22-2008, 03:35 PM   #3
Fav Mod: APS INTAKE
I felt it while raising the clutch pedal in gear.
Old 04-22-2008, 03:47 PM   #4
Car: 07 STi Blue
Fav Mod: stock :]
I have not had this issue...but my clutch pedal creaks when I release it...
I did not notice this in my 06...but im always blasting tunes...so maybe it did the same thing
bue car is offline   Reply With Quote
Old 04-23-2008, 02:55 PM   #5
Fav Mod: APS INTAKE
Just went to pick her up. Dealer replaced the clutch under warranty. Due to failure of pressure plate springs or splines. So my dealer replaced the entire clutch and throughout bearing under warranty. Would of cost me almost $2000 if it wasn't under warranty.
Old 04-23-2008, 05:41 PM   #6
Fav Mod: APS INTAKE
Default Re: Clutch replaced under warranty. Due to pedal vibration.
Pics of the work. Notice the very small burn marks.
Old 04-23-2008, 09:40 PM   #7
Fav Mod: APS INTAKE
Default Re: Clutch replaced under warranty. Due to pedal vibration.PICS
They also replaced oil in tranny.
Old 06-06-2008, 10:37 PM   #8
Car: 05 OBP STi
Fav Mod: B&B Exhaust
not to bump an old thread, but I'm having this same exact problem... what exactly did the dealer says was the cause? the pressure plate springs?
my car is six months out of warranty and I'm not looking forward to how expensive this might be to fix...
xnthuzst is offline   Reply With Quote
